Sponsored by: Real Truck
Stick on keyless entry
Old Mar 11, 2022 | 01:41 PM
Bubbas15's Avatar
Bubbas15
Trailering
I have a 2016 f250 crew cab long bed xlt 6.7
i have enabled the factory remote start and programmed keys etc. I purchased one of the stick on RF keyless entry keypads for the door. I have tried every way I have found online to program this with no success.
turning keys on and off to enter programming mode does nothing when I press the last two buttons on the key pad.
Any guidance on this would be greatly appreciated!
Old Mar 11, 2022 | 06:55 PM
Just Strokin's Avatar
Just Strokin
Do you know if your truck has remote key entry?......did you cycle the key 7 times and ten on the 8 turn, leave in the on position/....did the door locks cycle?
Your truck, if equiped with RKE, would use Type B for programming.
https://www.fordservicecontent.com/F..._11-6-2020.pdf
Old Mar 13, 2022 | 06:02 AM
Bubbas15's Avatar
Bubbas15
Trailering
I go through that entire process and the locks cycle, I reprogram my keys and the horn honks each time I press a button on a key to signify success but when I go to hit the last two buttons on the key pad I get no response from the truck. The red indicator light functions on the keypad so I know it’s batteries aren’t dead.
djpahan
Jun 16, 2013 06:11 AM
clayton_ray07
Sep 2, 2011 05:00 AM
craziejoker
Escape & Escape Hybrid
Apr 21, 2011 11:45 PM
drejw2
Jul 23, 2010 10:52 AM
gitair
Electrical Systems/Wiring
Sep 12, 2004 12:12 AM
