Above photo: showing my home-built 2x2 tube crossmember which bolts on using existing holes in the frame rails.
I began my "do-over" refurb in August 2020, and entailed lots of wire brushing, sanding, sandblasting & elbow-grease.
In this photo the auxiliary (belly) tank is not in place which goes just behind the NP205 transfer case.
Food for thought _ _ _ _
