6.7 F250 scan/programmer tool
Old Mar 9, 2022 | 04:58 AM
Crewcab Turbo's Avatar
Crewcab Turbo
Hello I have a 2013 F250 6.7 and I’m looking for a programming /scan tool with all the options and features. I’m looking to be able to change any and all factory options and add keys and change door codes and such. Anyone know what is a good one? Any links to one?
Thank You.
Old Mar 9, 2022 | 07:32 AM
Just Strokin's Avatar
Just Strokin
You can get FORScan along with an OBDII interface (WIFI/USB/bluetooth) for a laptop to make the changes you seek to change. You can not change the door key pad code for you truck. With two programmed keys, you can have it display in the dash.
Most will suggest OBD MX as the bluetooth OBDII interface but I have had goo luck with cheaper bluetooth models. OBD MX is $80 and up for even used ones.
Here are some links for you
FORScan
www.forscan.org
Spreadsheet for values that users have tried and proven to work
FORScan 2016 Super Duty - Google Sheets
Link to reporgram PATs with FORScan
Erase All PATS Keys 2016 F250 XLT - Ford Truck Enthusiasts Forums
Ford AsBuilt FTE link
FORScan and As-Built Data - Ford Truck Enthusiasts Forums
Ford As Built data link
Ford As-Built Data
Ford Free Resources
Free Resources - OBD system etc
Old Mar 9, 2022 | 04:59 PM
DTEC907's Avatar
DTEC907
FORScan
www.forscan.org
Ford As-Built Data
Ford Free Resources
Does that sheet work for the 2011's?
Old Mar 9, 2022 | 07:23 PM
Just Strokin
Most of it works for the 2011-2012's. I am not sure if there is any annotation on what doesn't work on the 2011-2012's. The radio/audio is one section that is different.
Old Mar 9, 2022 | 07:32 PM
jollyrogr's Avatar
jollyrogr
Here’s a link to the sticky in the superduty forum. There’s a spreadsheet there for 11-12’s
https://www.ford-trucks.com/forums/1...ces-index.html
Old Mar 10, 2022 | 08:45 AM
Dirthawg2.0's Avatar
Dirthawg2.0
The door pin code can be changed. I have a custom pin my salesman entered when I purchased the truck new.
I haven't tried the below process but here is what Ford says about changing the code.
https://www.ford.com/support/how-tos...-entry-keypad/
Old Mar 11, 2022 | 10:38 AM
Just Strokin
Dirt, the internal code in the PCM/ECU for the key pad can not be changed but you can add up to 5 personal codes of your own
Old Mar 11, 2022 | 10:46 AM
Dirthawg2.0
Thanks for that info Larry. That explains it!
Old Apr 4, 2022 | 10:29 AM
Crewcab Turbo
Thanks for the replies. Been busy. I did get FORScan and tried it. I cannot get my splash screen to change and I’m not sure why as it looks like it’s sending as it should be. I also can’t get my windows to go up with my keyfob. Seems like it’s kinda hit or miss on what works when I make changes. Any ideas? Thank You!!
Old Apr 6, 2022 | 07:35 AM
The Bone's Avatar
The Bone
I don't believe you can get them to roll up for safety reasons. I found mine down one day and turned that crap off. I don't want my windows to go down and rain overnight.
Old Apr 6, 2022 | 08:41 AM
jollyrogr's Avatar
jollyrogr
I haven't messed with the splash screens. I like the one that the truck has now. The changes I've made are disabling the door open chime with the engine running (sweet silence!), adding the numeric value above the coolant temp gauge, removing satellite radio from audio sources, and enabling OCR and the DPF screen. I've also used forscan to clear the air filter status error that I could not otherwise clear. (Apparently if you turn the key on with the maf sensor unplugged, you'll get an error on the air filter status screen that can only be reset with a scan tool though it does not set a DTC)
Old Apr 6, 2022 | 10:51 AM
Overkill2's Avatar
Overkill2
Man, I have to learn more about FORScan so I can use it one day.
Darrenkoke
6.7L Power Stroke Diesel
Jul 14, 2020 03:26 PM
husq_tech74
Jul 18, 2008 10:06 PM
xplor
Electrical Systems/Wiring
Feb 4, 2004 07:01 PM
vanner
Garage & Workshop
Apr 11, 2002 01:09 PM
