Typical fuel mileage
Old Mar 20, 2024 | 11:00 AM
knottyrope's Avatar
knottyrope
14 mpg hauling a 10k trailer, 6 people and a lots of toys
19 when unloaded with 35s
4.10 ZF5 CCLB
Old May 8, 2024 | 09:14 AM
Harveyearlolstad's Avatar
Harveyearlolstad
I think I heard on this forum already but want to confirm that... The ebps does not affect gas mileage when you deleted the ebpv?
Clint from custom works states in one of his videos that the ebps can affect fuel delivery to the motor regardless of the state of you ebpv. This guy seems very knowledgeable in the 7.3 platform.
Just looking for another possible reason I'm only getting 11-12 miles per gallon?
Old May 8, 2024 | 10:07 AM
knottyrope's Avatar
knottyrope
EBPS if too high, PCM will defuel and you will mash pedal to make up for it and there is the fuel delivery issue
Also affect shifts in an auto, too low of RPMs and you lug the engine making for worse MPG
NO EBPV can affect warm up in below freezing climates or make it run too cool which decreases efficiency of fuel burn
Old May 8, 2024 | 10:13 AM
Harveyearlolstad
So if I have a ebps code, then replacement could solve my terrible gas mileage,correct?
Thanks for the response
Old May 8, 2024 | 10:16 AM
BuckHammer's Avatar
BuckHammer
Originally Posted by Harveyearlolstad
I think I Just looking for another possible reason I'm only getting 11-12 miles per gallon?
Gosh, as you are aware, that’s remarkably poor. I was recently getting 14-15mpg with a pretty aggressive fuel leak and 285x75R16 tires.
Old May 8, 2024 | 10:37 AM
96SD's Avatar
96SD
I know when I changed my EBPS I needed a new line too, it was 100% clogged no amount of cleaning could get the garbage out. I tried the carb cleaner and weed eater line deal. I have heard conflicting theory on the EBPS and manual transmission. I don't really care. Replaced the sensor and the line and wont worry about it for 15 years. Just throwing that out there.
Old May 8, 2024 | 10:52 AM
Harveyearlolstad
Well actually I cleaned the line about a year and half ago with an aircraft cable on the end of a drill. I was a real pain. But the sensor can still be bad. I will check it out and see. $100 dollar sensor is worth it if it cures my mileage issue but would rather not spend the cash if it doesn't.
Old May 8, 2024 | 10:57 AM
96SD's Avatar
96SD
Just didn't want you ordering a sensor to find you also needed the line. I just did that with Bronco graveyard. Ordered O-rings and then found out the next day I needed some bolts. Ate shipping twice.
Old May 8, 2024 | 01:59 PM
knottyrope's Avatar
knottyrope
if you get the EBPS tube off, re use the fittings and flare up some brake line for 10 bucks.
Took me 15 minutes to cut, bend and flare vs the 2 hours of try to clean the tube that been there who know how long with carbon build up
Old May 8, 2024 | 05:58 PM
White95PSD's Avatar
White95PSD
Can you delete this tube? Or is there a bypass?
Old May 8, 2024 | 08:31 PM
z31freakify's Avatar
z31freakify
Is your truck auto or manual?
IIRC I think I read that the ebps is used on autos for fueling and shifting strategies I may be wrong, maybe Cleatus12r can chime in and give his thoughts on it.
Old May 8, 2024 | 08:45 PM
Harveyearlolstad
Truck is auto. Seems to shift fine.
Americanmadeford
1983 - 2012 Ranger & B-Series
16
Jul 17, 2008 10:49 AM
2 stroke man
Jan 22, 2008 07:34 PM
redbull660
Aug 30, 2004 06:03 AM
FireMarshal3311
Feb 19, 2004 08:58 PM
Halfast
Jul 5, 2003 04:15 PM
