hey my dad recently traded his 99 6 speed powerstroke ext. cab short bed with 3.73 gears on an 02 crew cab short bed with 3.73's. with them tuned the same (60 hp), and no catalatic conv. on either truck he could easy get 20 mpg mixed driving with him driving, but not with me driving lol. well, his 02 gets only about 14 at best with same driving. thats pretty rotten imo. i get 16.5ish with my 97 4.10's auto ext. cab lwb on 90 hp lead footed with intake and straight pipe.
what do you all get, is there some reason you can think of as why the drop?
my 02 was like that, just got it recently, when installing my DP today i found out it had a Superchip in it and it ran like crap... maybe check out pcm and see if its chipped Dave
Did he switch from a stick to an auto? An auto likes to rev higher rpm's with the same amount of pedal. Try keeping it under 2,000 rpm's all the time and see what the mileage does.
If that's not it maybe try cleaning the EPB sensor tube. I get a hair under 20 in my 02 6 speed.
she'sbone stock 'cept for the superchip dad put on it. i'm gonna tow my wrecked stroker tommorrow on a 7,000 pound flatbed to make ~14,500 pounds with it on stock to see if it gets better fuel mileage. yes, he went stick to auto
i towed my truck on our 7,000# trailer behind dad's truck 50 some miles today, then hauled just the trailer probably 20 miles then hauled an 800 pound role of hay back home, which was 30 miles back. then some in town empty driving tonight. 126 miles, 13.39 gallons of diesel= 9.45 mpg!!!! that sucks, and thats with clean air filter, only 15 minutes max idle time, and on stock setting!!. my truck with 4.10's gets that turned up 90 hp blowin smoke runnin much harder than i ran his today with 22,000+pounds will get 10mpg. no raw fuel smell, no drips, not alotta smoke either! any ideas????
ok. it had the turbo start leaking oil b4 he bought it so a new turbo was installed. maybe they didnt get stuff tigghtened up good. where are spider boots?
Heres a better explaination, you will have the intercooler pipes coming into the y portion of the spider pipe then there are 2 other pipes angled down with orange boots that go to the engine.
148,000 ish miles. i aint had time to check boots yet. i heard something bout map sensors causeing that sortta prob? i had a turbo last year, so i'm thinking she wasnt hooked back up good
All i expect and usually get around town in my truck (pretty similar to his) is 13.5 ALmost always dead on hand-calculated every time, towing or not. Highway is better, just don't do enough of it to find out how much. Last I saw 17 on the highway with ULSD. 19 with Low sulfur diesel!!!! Get rid of the earth bunnies so we can get our mpg's back!!!!!!
