Broken climate selector
Old Mar 8, 2022 | 04:44 PM
coopers89F250's Avatar
coopers89F250
4wd Low
My temperature selector switch gets super tense after I move it past the middle toward the hot section the springs back to the middle when I let go, my cold air also stopped working about the time this happened anyone know how to fix?
Old Mar 8, 2022 | 04:54 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Is this on the ‘89 F-250 in your user name? The temp door is controlled by a cable. My guess is something is inside the heater box preventing the door from moving.
EDIT: The temp blend door is behind the glove box Remove the glove box to watch the end of the cable.
Old Mar 8, 2022 | 07:02 PM
yardbird's Avatar
yardbird
Or the clamp that holds the cable to the control unit has broken. That happened to mine. I used an old style, wrap around cable holder like was used on tiller throttle cables many years ago to mount the cable back.
You can reach up under the glove compartment and feel/see where the cable hooks to the control door. If you can move the door rod back and forth, and the cable is hooked where it should be, then the problem is at the control panel.
Old Mar 9, 2022 | 09:11 AM
Moongypsy's Avatar
Moongypsy
When I bought my '91 the controls were binding also, but after removing the heater core assembly and reassembling it all is good. I think the cable assembly was kinked because it works perfectly now.
Old Mar 11, 2022 | 01:53 AM
coopers89F250
4wd Low
I just put a new heater core in so this seems most likely I’ll check on it first thing tmr morning, thank you so much for the help!
just fixed it you were right I clicked the cable into the wrong spot so it was binding, now I just have to figure out why it only blows through the defrost vents thank you so much again
Old Jun 1, 2025 | 11:40 AM
Gimmea250swb's Avatar
Gimmea250swb
Good news, the stick in the door was nowhere as bad as I thought. I was able to re-engage the white pieces and it held in place. Movement is smooth.
unfortunately I forgot to take a picture. The cable does clip into whe white block for future reference
finitetime
Nov 16, 2018 10:18 AM
66with352
1997 - 2003 F150
Aug 16, 2016 08:31 PM
RJR
1978 - 1996 Big Bronco
Jan 29, 2005 05:17 PM
f100guy
Dec 24, 2004 10:29 AM
borin&strokin
Dec 11, 2003 03:07 PM
