Engine swap. Intake runner valve delete/bypass?
Old Mar 6, 2022 | 07:03 PM
DarrellinCeres's Avatar
DarrellinCeres
I have a 98 Expedition 5.4 that I am doing an engine swap on. I swapped in a 2003 F350 5.4. So 260hp to 350hp swap
Everything went as expected with the parts swap. But I missed one thing that I don't see on the newer engine. Or it is in a different place and I missed it during assembly, but I don't think so. Anyway I have a extra connector.
The old engine had a intake runner valve ( f75e-9l490-db) the new model doesn't appear to have one.
Anyone run into this problem? Will it set the CEL? Can it be deleted with a tune? Can I trick it (dummy load)?
Appreciate your words of wisdom
Old May 17, 2022 | 07:03 PM
DarrellinCeres
Just an update for anyone who comes across this with the same question.
I ohm'd out the valve and it was about 160ohms so I took two 330 1W resistors in parallel and plugged them in to the connector. Taped it up and wrapped in friction tape then tucked it under the alternator so you couldn't see it
No codes and passed smog like a champ
BiggBlack02
Mar 30, 2020 09:59 PM
Tonyhawksunderground
Sep 24, 2018 05:22 PM
aztirefil
Engine Swaps
Aug 20, 2017 09:17 AM
mharring
Oct 18, 2010 07:32 AM
