I’ve just graduated from a bumper pull to a 5W (GD 303RLS - 33’). The manual suggest installing a battery isolator “to independently charge both the RV auxiliary battery and the tow vehicle battery” and to “prevent the RV from draining your tow vehicle battery”. Why? My tow vehicle is a 2020 F250 6.7 diesel with dual batteries. Is it because the RV fridge is now 12v instead of the Dometic LP gas/120v like we had in the previous RV? Is the alternator output insufficient to run the new fridge while towing? Been towing for years but this is new to me. Thanks
No need. With the truck off the pcm does not allow current through the 7 pin.
When parked, disconnect from the 5th wheel anyway since you are at your destination.
We travel cross country and will stay at Walmarts and such. For those I don't disconnect. No issues since current is not allowed to pass thru the 7 pin.
Your truck will disable the 7-pin connector’s trailer battery charge circuit when the ignition is switched off, so there’s no need for another battery isolator.
Many of us have found there’s limited voltage and current available from the 7-pin connector’s trailer battery charge circuit due to small wire size. You may be able to run the fridge on 12V, or you may be able to (partially) charge the trailer house batteries, but you’ll likely not be able do both simultaneously.
If you want to do both, you might consider a separate high-amp / large AWG circuit from the truck to the camper batteries, preferably via a DC-DC charger located in the camper.
Thanks for all the info. I didn’t mention that the RV came with a 165W solar panel that trickle charges the RV battery. My assumption is that I would have to add panels to keep the fridge running during a 2-day, 1000-mi trip. Am I over thinking this?
No the truck will covey enough power to keep the fridge running and charge the battery while driving.
Is the fridge 12V and propane capable? I run mine on propane until plugged into shore power.
The 303's with a solar package get the 12 volt compressor fridge. Not the absorption fridge like the old days. It pulls about 6 amps DC when the compressor is running.
The fridge will be fine, it only pulls about 6 amps when running the compressor. So the truck can keep up with that just fine.
And the compressor is not running constantly once the fridge is cooled down so with solar on the roof while running down the road with the truck there should be no problem. The greater issue may be if not on the shoreline with cloudy days and a lengthy stay. May well depend on how rig is used.
Thanks for the education guys! This is a great site. I hope to contribute more than I get as i get past the newby stage of diesel driving and FW towing. Many years of gas and bumper-pull. Old dog…new tricks.
