6.5-7 MPG issue
Old Mar 3, 2022 | 10:39 PM
MeanLeanRedMachine's Avatar
MeanLeanRedMachine
6.5-7 MPG issue
Hey guys so I think I have an issue but I might know the answer to a certain degree. My issue is 6.5-7 MPG on average commuting while driving like a normal person. So I have 91 f150 351w e4od 4x4. 35s and a 4 inch lift which is part of my issue and here’s the kicker 3.55 rear end gears. Could it just be the tire to gear ratio that’s messing me up so badly or could there be something else?
Old Mar 3, 2022 | 10:43 PM
SFaulken's Avatar
SFaulken
Is this something that just started, or has the mileage always been that bad?
Old Mar 3, 2022 | 10:46 PM
MeanLeanRedMachine
Well I’ve just started driving it regularly so I’ve never checked the mpg since it was just a farm pickup that barley got used. But the last 2 months I’ve really noticed it though
Old Mar 3, 2022 | 10:50 PM
SFaulken's Avatar
SFaulken
Your mileage isn't ever going to be good in that configuration. But what you're reporting is lower than it should be. Do the KOEO tests, it wouldn't surprise me in the least if your ECT is bad.
Old Mar 3, 2022 | 10:57 PM
MeanLeanRedMachine
So what is a KOEO test and what is a ECT. I have a scan tool for my truck. And I do also plan on doing a 4.11 swap this summer with a ZF5 which hopefully will help.
Old Mar 3, 2022 | 11:05 PM
SFaulken's Avatar
SFaulken
KOEO = Key On Engine Off
ECT = Engine Coolant Temperature sender
If you've got a basic OBD2 scan tool, it won't work with this truck, you'll need something like an Innova 3145, or read the blink codes. (Personally, I'd rather sandpaper the arsehole of an alligator in a phone booth, than read blink codes, but you do you.)
Old Mar 3, 2022 | 11:15 PM
MeanLeanRedMachine
Ok well I have a OBD1 blink code tool so it’s what I’ve got. I’ll scan it tomorrow and see what I get last time I scanned it it was freaking out about not having cats and a couple vacuum issue which I have fixed
Old Mar 4, 2022 | 06:16 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Our PCM's dont know that our trucks have cats, there's nothing to tell PCM the cats are there, like newer trucks, that have O2 sensor after the last cat to show a difference. O2 sensor is how old?
Old Mar 4, 2022 | 08:33 AM
Mudsport96's Avatar
Mudsport96
So, are you calculating mpg bassed off of the trip odometer? If so, with 35s your speedo will be way inaccurate. Could be part of the problem.
Old Mar 4, 2022 | 08:38 AM
MeanLeanRedMachine
I probably do need to replace the o2 I didn’t know last time it was changed. The way I did mpg was through my gps and my tank levels
Old Mar 4, 2022 | 09:05 AM
Conanski's Avatar
Conanski
That is no good either because these fuel gauges are notoriously inaaccurate. You need an accurate measure of the distance travelled and the fuel consumed, a gps is better than your ODO at this point so that part is fine but start with a full tank and use the amount of fuel needed to refill the tank to the same point(when the filler shuts off) as the fuel measure for the calculation. You don't have to completely drain the tank you could only run it down to an indicated 1/4 or 1/2 tank for example. the more you repeat that the more accurate the average of them all will be and this will also give you an better idea of just how far off the fuel gauge is.
Rooftop
2015 - 2020 F150
85
Dec 27, 2017 09:37 AM
dmeyer 351 4x4 rebel
54
Jan 27, 2011 11:09 AM
Hellonwheels
42
Apr 15, 2008 01:20 PM
tankrsc
Apr 5, 2008 08:17 PM
tmcgin
Feb 9, 2006 03:22 PM
