2011 6r80 code po705
Old Mar 3, 2022 | 07:21 PM
4x4k20's Avatar
4x4k20
got a 2011 f150 4x4 the r680 transmission is acting up it stays in drive and dosent want to shift to any other gears the shift indiactor lites up and then goes blank i cant find no a netural switch on the side of the transmission so i dont know what to look for for a fix i guess it has some thing i dont know about any ideals ?
Old Mar 3, 2022 | 07:50 PM
RLXXI's Avatar
RLXXI
If you have less than 150,000 miles on your truck the repair is free. The lead frame needs to be replaced.
Old Mar 3, 2022 | 08:48 PM
4x4k20's Avatar
4x4k20
thanks for that info.the truck has 230k i will check into more about this lead frame i read a little about that part needing to be replaced maybe thats my problem i have worked on alot of trucks and never seen one act up like this it would be in drive but you would be in reverse at the same time
Old Mar 6, 2022 | 05:22 PM
4x4k20's Avatar
4x4k20
the lead frame which is the best one to get ? also i see most are aftermarket or refurbished i want a good one
Old Mar 10, 2022 | 12:01 PM
rsylvstr's Avatar
rsylvstr
how did this turn out?
Motorcraft only from what i hear...
Old Mar 13, 2022 | 08:37 PM
4x4k20's Avatar
4x4k20
still looking for a good lead frame gonna talk with a couple transmission shops and see what they recommend as far the one they would use i would like to replace it my self but will see what they would charge to replace it.
Old Mar 14, 2022 | 05:55 AM
rsylvstr's Avatar
rsylvstr
in central NY, they were all $500 last year, including the dealer. I was lucky and my local dealer looked in the system and told me where the nearest dealer was that had the part in stock.
You may have luck stopping by your local dealer and asking the parts counter.
Old Apr 29, 2022 | 09:24 PM
4x4k20's Avatar
4x4k20
i bought a refurbished valve body with the lead frame put it in the truck and still no good it wont start unless i jump it to the solenoid and it has no indicators lights at all caught hell trying to remove the transmission pan the rear bolts heads were stripped out i had to drop the exhaust to get to them so i am rite back at square one.. i pulled the front engine fuse box and if i try to check the fuses they wont show no power until i push down hard on the fuses i got a big mess is what i got
Old Apr 30, 2022 | 05:54 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I may be wrong but I think this also came with a 10 year time limit.
Old Apr 30, 2022 | 09:28 AM
gDMJoe's Avatar
gDMJoe
Post
tseekins - I may be wrong but I think this also came with a 10 year time limit.
Excerpted from the following notification - Customer Satisfaction Program 19N01 ...
PROGRAM TERMS
This program extends the warranty coverage of the automatic transmission molded leadframe to 10 years of service or 150,000 miles from the warranty start date of the vehicle, whichever occrs first.
tarditim
Oct 12, 2011 03:29 PM
eakanator
Jul 13, 2002 02:23 PM
fjones
Jul 10, 2002 08:06 PM
