E Coat Frame
Old Jun 30, 2024 | 10:35 AM
kITEBOY 62's Avatar
kITEBOY 62
1st Gear
e-COAT
Originally Posted by nate84
I’m getting my frame acid dipped and they’re offering to E-coat it for a few hundred dollars. Does anyone have any experience with E-coating a frame? Would the E Coat itself be enough to protect the frame from rust? Do I still need to paint it or put a clear coat on it or can I go straight to putting my truck back together? I know F-150 frames nowadays are E-Coated but I’m unsure if they put any additional protection on it.
E
i KNOW THIS REPLY IS NOT TIMELY BUT i WORKED IN AN AUTO ASSEMBLY PLANT FOR 25 YEARS, 12 OF WHICH WERE AS A PAINT INSPECTOR. E-COAT (ELECTRICLY BONDED COATING) IS PERHAPS THE BEST WAY TO INHIBIT RUST. UNLIKE UNDERCOATING IT DOES NOT TRAP MOISTURE AND RARLEY BRIDGES THIN GAPS. I HAVE A 1999 SVT LIGHTNING, THIS YEAR I WILL BEGIN TO DETAIL THE UNDERBODY. IF IT WAS A BODY OFF REBUILD I WOULD ABSOLUTLY GET IT DIPPED. IN MY CASE HOW EVER I WILL SUBSISTUTE USING SELF ETCHING PRIMER WITH A CLEAR MATTE TOPCOAT. THE DULL GREEN FROM THE PRIMER LOOKS VERY MUCH LIKE E-COAT. I'M NOT SURE WHAT FORD USES ON TRUCK FRAMES IF ANYTHING. THOUGH IT IS LIKELY THEY DO USE. AN E-COAT BATH. THE REAL KEY TO THE TENDANCEY FOR FORD TRUCK FRAMES TO NOT BE PRONE TO EARLY RUST OUT IS THE QUALITY OF THE STEEL THEY USE.. CHEAP STEEL WITH IMPURITIES LEADS TO EARLY RUST OUT ESPECIALLY IN A ENVIROMENT THAT IS CORROSIVE LIKE SALTED ROADS. THE VALUE OF HIGH QUALITY STEEL IS SOMETHING THAT FORD HAS ALWAYS UNDERSTOOD UNLIKE OTHER TRUCK MANUFACTURERS. (THIS MEANS YOU DODGE).
Fordranchero
Jul 12, 2011 04:25 AM
jm ray
20
Aug 1, 2008 09:59 AM
1970Custom
General Automotive Discussion
Jun 3, 2006 10:40 PM
IowaTower
Paint & Bodywork
Jan 25, 2006 11:07 PM
otto
16
Jul 31, 2001 06:14 PM
