New here CHT question.
Old Feb 28, 2022 | 08:56 PM
PincheGringo's Avatar
PincheGringo
Brand new 4.6 engine was installed in my 2010 F150 XL a few months ago. Truck pegged out the tempature gauge on the way home but settled quickly after I pulled off the road. Before I noticed the fans kick on high every 5 minutes. I hooked up my scanner and looked over the codes. Bank 2 sensor 1 o2 sensor was the only code. So I looked at the CHT °F and it was floating between 215-230°F. That has me a bit nervous. No coolant in the oil. I replaced the thermostat and wated pump for giggles to see if it would help. Fans still kick on high every 5 minutes and CHT hasnt changed. Clogged cats? Any suggestions?
Old Feb 28, 2022 | 09:55 PM
gDMJoe's Avatar
gDMJoe
Question
PincheGringo ... 4.6 engine...
2V or 3V?
...Bank 2 sensor 1 o2 sensor was the only code...
What was(were) the particular DTC(s)? *Most obvious would/could be MAF and or air intake/exhaust leak related.
...replaced the thermostat
Is it a Motorcraft? *If not, it needs to be.
Also... Are you sure that the cooling system was properly burped?
As per the repair manual...
Old Mar 1, 2022 | 01:09 PM
maco's Avatar
maco
As said above use an OEM thermostat !! My experience has been with a 2011 & 12 5.0 engines... In both cases thermostat was changed while replacing other parts as a precaution (heater hoses & w/pump) In both cases non OEM stats were used as a replacement causing immediate higher heat conditions which also made the fans go to extreme high cooling !!!
Old Mar 1, 2022 | 03:58 PM
pdqford's Avatar
pdqford
And what was the actual temp of the coolant?
redxl1664
Mar 17, 2018 05:55 PM
idlewild
1983 - 2012 Ranger & B-Series
Jun 30, 2011 06:01 PM
Rcmgiasson
1997 - 2003 F150
Nov 26, 2007 09:31 PM
shultzy501
1997 - 2003 F150
Feb 11, 2005 10:20 PM
neil52
1997 - 2003 F150
Jan 16, 2005 03:25 PM
