Power steering bleed
Old Feb 28, 2022 | 09:34 AM
rothrojc's Avatar
rothrojc
3rd Gear
I have a 2004 excursion rwd with a 6.0. Getting ready to replace the hydroboost, power steering gear, power steering pump and all lines. What is the proper sequence to bleed everything so I don't tear anything up in the process?
Old Feb 28, 2022 | 05:06 PM
SmackDaddy's Avatar
SmackDaddy
Look in the Tech Folder at the top of the page.
Old Feb 28, 2022 | 06:27 PM
pirate4x4_camo's Avatar
pirate4x4_camo
No idea what technique is in the tech folder
i put the front axle on jack stands,
Engine OFF !!!
turn the wheel lock to lock 5 times
depress brakes 3 times
that is one full cycle.
repeat 50 full cycles.
start engine and test turn lock to lock and brake.
Any whining whatsoever, immediately stop engine. Wait several hours ( overnight is better ) repeat 25 full cycles.
once you hear the whine you have air bubbles in your fluid and further bleeding is pointless until the bubbles come out of suspension. *Get it frothy enough and you need to change the fluid and start over.
* these are the guys who will tell you all ford power steering whines.
robertpayne14
6.4L Power Stroke Diesel
Feb 21, 2022 03:24 PM
DerekP
Aug 1, 2021 03:20 PM
Motoryder714
1983 - 2012 Ranger & B-Series
Dec 21, 2001 12:13 PM
