07, 6.0 dies while driving
Old Feb 25, 2022 | 07:42 PM
Tboycat's Avatar
Tboycat
Got a 07 f350 with 6.0 all stock, egr deleted.resealed top end about 8000 miles ago.runs great for about 20 minutes then just dies, sit on side of road for1 1/2 hours and it will start and run about 20 more miles, I’ve been thinking a oring somewhere and when oil gets warmed up it starts leaking and dies from loss of pressure, when it cools off it starts back. Now I’m wondering if something in ficm may be gettin hot and shutting down, it has no diagnostic b can codes. Also when it dies I can try to start it with scanner hooked up and it won’t build any high pressure .(high pressure oil pressure). Anybody have any thoughts on this
Old Feb 25, 2022 | 08:25 PM
bismic's Avatar
bismic
What are you using to scan for codes?
Old Feb 25, 2022 | 08:30 PM
Tboycat's Avatar
Tboycat
Genisys evo
Old Feb 25, 2022 | 08:32 PM
Tboycat's Avatar
Tboycat
Sometimes it will log a low injection pressure code
Old Feb 25, 2022 | 08:37 PM
Tboycat's Avatar
Tboycat
Also when I first turn key on, I can hear it clicking the injectors, after driving it , when it dies, u can turn key on and not here the clicking sound, only hear electric fuel pump. After sitting for hour and half it starts and so glad I take off and not sure if it made clicking noise or not.
Old Feb 25, 2022 | 08:40 PM
Tboycat's Avatar
Tboycat
Also has upgraded stc fitting ,and new standpipes and dummy plugs.(oem ford motorcraft parts)
Old Feb 26, 2022 | 09:01 AM
SmackDaddy's Avatar
SmackDaddy
Either a high pressure oil leak that causes a loss of oil pressure once warmed up or possibly a failing IPR or ICP or both. Have you checked the IPR?
ballbandit
Jul 11, 2016 10:52 AM
Loftatsea
Apr 26, 2016 12:19 AM
Jesse Ratliff
Dec 1, 2015 10:20 AM
bpete
Jul 16, 2014 06:28 PM
DaGovna
Apr 22, 2013 11:14 AM
