97 F250 level
Old Feb 25, 2022 | 04:14 PM
CO460's Avatar
CO460
97 F250 level
Hello-- I am trying to level my 1997 F250 460. I want to do new front leaf springs and shocks. I am wondering if I should go with a 2" or 2.5" lift leaf spring, or will a fresh new stock spring raise the front enough? I was thinking it might have just sagged over its 25 year life. Any experience swapping front leaf springs is welcomed. Thanks
Old Feb 25, 2022 | 05:00 PM
rla2005's Avatar
rla2005
New factory springs will restore the front height but it will not level the front.
These trucks were designed with a bit of a rake. If you want to level the truck, why I have no idea, you need a set of front lift springs and adjustable bushings at minimum to correct the camber/caster. Worst case are drop brackets for the axle sections as well.
Another option is putting 500 lbs in the bed.
Old Feb 26, 2022 | 10:07 AM
obsxl's Avatar
obsxl
SAS it with some new f350 springs and you’ll gain around 2 inches and be rid of TTB. two birds with one stone
78pace
Apr 3, 2011 12:50 PM
gt40racing
Jan 12, 2011 06:29 AM
RobPStroker
Dec 2, 2005 01:45 PM
bigg
Nov 17, 2003 02:19 PM
