Since I bought this a few weeks ago I can’t figure the problem out.. when switching to 4x4 the dash and all electrical go crazy flashing , traction control light came on, abs , and brake light along with the wrench icon also went into limp mode (3rd gear only). I checked for codes while running and nothing came up other than a pending code of U0073 but I think that’s caused by the electrical surging. If I switch back to 2wd and turn the engine off and restart it will drive okay as long as I do not switch to 4x4
Sounds like the smart junction block has issues. Very difficult to diagnose. Basically replace and see if replicates. Not really a diy as I believe some programming is involved.
