Side light delay or speed adjustment
Old Feb 24, 2022 | 03:28 PM
akajones's Avatar
akajones
I haven't started Forscan on my 22 yet, but it was great on my 19. Does anyone know if Forscan (or anything for that matter) can help with keeping the side mirror lights on for more than 5mph? I'd like to have them stay on til about 15mph so I can use them more while plowing. Any ideas?
Thanks everyone.
Old Feb 24, 2022 | 03:34 PM
4wd6.7L's Avatar
4wd6.7L
Spot Lamp Low Speed Override Adapter — Boosted GreyGoose Designs
There is a no cost mod you can do but might require clipping a wire. Also, Wicked Warnings sells some options that allow use of those lights at any speed and also include a strobe module.
Old Feb 24, 2022 | 03:37 PM
akajones's Avatar
akajones
Thanks! That'll do it!
Does anyone know of a DIY or cheaper hack? I'd rather not spend $50 plus if I don't have to.
Old Feb 24, 2022 | 09:27 PM
ibeb's Avatar
ibeb
Not 100% sure if this is the same for your rig, but here is a no/low cost mod.
I just used a wire tap to do it on mine, switching the hot until 5mph wire to the one thatbis hot all the time, didn't disassemble the module.
https://www.fordtremor.com/threads/s...63/#post-47151
Old Feb 26, 2022 | 10:15 AM
dzdiggin'dude's Avatar
dzdiggin'dude
Anyone do the mod in the video? Does it turn off with key? I'm afraid I would forget to turn off.
Old Feb 26, 2022 | 10:18 AM
ibeb's Avatar
ibeb
The wire that is right there to tie into is hot all the time. You could run a lead to a switched wire if you're worried about it. I thought about running it to an upfitter, but just used what was there.
Old Feb 26, 2022 | 10:20 AM
dzdiggin'dude
Thanks and have a good day.
Old Feb 26, 2022 | 11:06 AM
Ding126's Avatar
Ding126
another option but more than most will want to spend.
https://www.wickedwarnings.com/produ...o-flasher-kit/
Old Feb 26, 2022 | 11:19 AM
4wd6.7L's Avatar
4wd6.7L
I did, but on sale for something like 20% off. Also, I wanted to retain the independent left and right spot light function, like stock, along with the speed override, and have the strobe functions turned on by upfitter switch. He had no problem making one custom to function as I wanted.
hardgear69
Oct 29, 2021 11:48 AM
Steelhant
Aug 14, 2018 10:21 PM
Cornbred
Jul 27, 2017 01:17 PM
unclehan
General Automotive Discussion
Sep 12, 2005 12:47 PM
