Side mirror marker lights
Old Oct 28, 2021 | 08:13 PM
hardgear69's Avatar
hardgear69
I have 2018 F-350, want to put switch back side mirror marker lights on it, the ones i have found say they only work with daytime running lights,. Which ones will work or do I need to change settings in forscan. I would like the white LED running light and Amber LED blinker.
I posted a link to the ones on amazon
Amazon.com: [Switchback + Sequential Turn Signal] VIPMOTOZ Chrome Housing White & Amber LED Strip Side Mirror Indicator Light Blinker Lamp Replacement For 2017-2021 Ford F-250 F-350 F-450 Super Duty Towing Mirror : Automotive Amazon.com: [Switchback + Sequential Turn Signal] VIPMOTOZ Chrome Housing White & Amber LED Strip Side Mirror Indicator Light Blinker Lamp Replacement For 2017-2021 Ford F-250 F-350 F-450 Super Duty Towing Mirror : Automotive
Old Oct 28, 2021 | 09:01 PM
4wd6.7L's Avatar
4wd6.7L
The oem side mirror lights do illuminate when the parking lights are on (running light), if that's what they are referring to. When you turn your parking lights on, or headlights, are your side mirror lights lit?
I would think white marker lights would be illegal in some places though...not that this kinda stuff gets enforced much.
Old Oct 28, 2021 | 09:07 PM
zeroo's Avatar
zeroo
Those are actually spotlights controlled by the 2 switches under the left hvac vent. They only work if your under 5 mph. I just bought a plug in adapter that will allow you to switch them on at any speed.
I guess they replace the the blinker and spot light.
Old Oct 28, 2021 | 09:16 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by zeroo
Those are actually spotlights controlled by the 2 switches under the left hvac vent. They only work if your under 5 mph. I just but a plug in adapter that will allow you to switch them on at any speed.
The words used in the add he linked say, "running lights', "parking lights",in reference to the white light. Nowhere does it say spot light. That's not to say you are wrong. It very well could be a poorly written description. The OP never stated whether he has the spots or not either. Not all Super Duty's have the spot light function.
Mine does, and like you, I also addded a speed overide harness to my spot lights, as well as an integrated strobe function.
Old Oct 29, 2021 | 08:32 AM
hardgear69's Avatar
hardgear69
Side marker lights
My truck has 4 pins on the harness, but only has 3 on the stock light. I installed the running light did not work on any light setting, was amber when i opened the door. worked as should with turn signal. I do not have spot lights.
Old Oct 29, 2021 | 11:35 AM
KU4OJ's Avatar
KU4OJ
Can we get a link to that? I have read about opening up the little module box and shorting 2 pins together, but this seems like a lot less invasive and quicker solution.
Old Oct 29, 2021 | 11:48 AM
4wd6.7L's Avatar
4wd6.7L
Pretty sure there is another, simpler way that doesn't require opening the module but here is one source for a plug n play option. https://www.boostedgreygoosedesigns....erride-adapter
chocolatechip3512
Jul 4, 2024 09:04 PM
happy1426
Feb 5, 2020 01:29 PM
Cameronr124
Jan 22, 2020 12:41 AM
Rob Seitzinger
Nov 1, 2018 09:22 AM
93-331-29PSI
6.7L Power Stroke Diesel
Dec 28, 2014 04:29 PM
