351m intake manifold
Old Feb 23, 2022 | 04:02 PM
Iceman_77's Avatar
Iceman_77
I have a 77 that has a 351m with an upgraded intake manifold. I'm buying a 75 from a buddy of mine that has a 390 in it. I'm going to put the 390 in my 77. I was wondering if the intake from my 351m will work with the 390?
Old Feb 23, 2022 | 04:06 PM
mwoj's Avatar
mwoj
Negative. 390’s are part of the FE engine family. FE intakes are a little odd and unlike other engines. If you look at the valve cover, it actually sits partially on the intake. I believe the pushrods also go through the intake.
So long answer short, no.
Old Feb 23, 2022 | 04:33 PM
85e150's Avatar
85e150
Welcome to FTE!
Be aware that all FE engines become 390s on sale day. Before you buy, check the stroke. 3.5" is a 360, 3.78" is a 390. As OEM, a 4x4 never had a 390.
Also note that while a '75 390 will outpower a '77 (or any other year) 351M, the pickup 390 is not some firebreather and is "soft" compared to the performance engines in cars.
So make sure all that work you're going to do gets you what you want.........and good luck!
Old Feb 23, 2022 | 04:45 PM
Iceman_77's Avatar
Iceman_77
I was thinking it wouldn't work. Just wishful thinking I guess haha.
Old Feb 23, 2022 | 04:47 PM
Iceman_77's Avatar
Iceman_77
Originally Posted by 85e150
Welcome to FTE!
​​​​​​THe 75 with the 390 is a 2wd truck.
basically I was just wanting a little more power. I feel like the 351m in my 77 is lacking a good bit.
Old Feb 23, 2022 | 06:14 PM
ivsamhain's Avatar
ivsamhain
351m/400 intakes have been unobtainable for over a year, you shouldn’t have any trouble selling it. A used US made Weiand just sold for 285 on that auction site this week.
Old Feb 23, 2022 | 06:17 PM
440 sixpack's Avatar
440 sixpack
The intake is the least of your problems. the 390 isn't going to bolt to your transmission / bellhousing or much of anything else. if you can steal some parts off the donor vehicle it will make it easier.
Old Feb 23, 2022 | 06:52 PM
Iceman_77's Avatar
Iceman_77
OK. I might put my old intake back on the 351m before I put it in the 75.
Old Feb 23, 2022 | 06:53 PM
Iceman_77's Avatar
Iceman_77
Well crap. I figured I could take the bell housing from the 75 and use it with the motor.
Old Feb 23, 2022 | 09:40 PM
85e150's Avatar
85e150
The bell will bolt up to the transmission, so if you have a manual transmission bell and clutch on the 390 it should bolt up to the transmission. Engine mounting and exhaust etc will have to be sorted out.
Old Feb 23, 2022 | 10:39 PM
Iceman_77's Avatar
Iceman_77
Yep I didn't even think about the exhaust. Thank you sir
Old Mar 1, 2022 | 11:28 AM
njdevil77's Avatar
njdevil77
I have an Edelbrock Performer for a 351M that I replaced when rebuilding. It has some pitting on a couple of the runner ports where it meets the head. If anyone wants it let me know. Maybe we can work something out.
YooperUno
Feb 17, 2014 10:26 AM
LBF
28
Aug 1, 2010 04:53 PM
IowaTower
Jan 29, 2006 02:30 PM
tastyklair
Jul 19, 2005 09:16 PM
