Intake Manifold
Feb 10, 2014 | 06:33 PM
Intake Manifold
I have a 1977 Ford with a 351M engine will a Intake manifold off a 400 fit it 4bbl Intake Thanks in advance
Feb 10, 2014 | 06:46 PM
Yes, Except for the pistons and crankshaft, and harmonic balancer, the ford 400 and 351m are the same engine.
Feb 10, 2014 | 08:07 PM
Thank You Ordance
Feb 10, 2014 | 09:33 PM
Almost anything can be switched between the FE blocks.
Feb 11, 2014 | 06:35 AM
That is true, however the 351 and 400 engines are not FE blocks.
Feb 11, 2014 | 02:50 PM
351m & the 400 are in the 335 series of engines, the 2v heard on a 351c fit as well
Feb 16, 2014 | 12:17 AM
Actually the harmonic balances are the same too.
My bad - see post below!
Feb 16, 2014 | 12:53 AM
Quote:
Originally Posted by
SDDL-UP
Actually, this is not necessarily true, it depends on the application.
The 1980/89 FoMoCo Light Truck Master Parts Catalog lists two part numbers, one for each engine:
D5AZ-6316-A for the 1980/82 351M
D2AZ-6316-C for the 1980/82 400
I forget what the differences are but I've seen
NumberDummy explain it here before...
This might help:
https://www.ford-trucks.com/forums/6...-balancer.html
Feb 16, 2014 | 07:53 AM
You guys at the end are just talking about the harmonic balancer not being the same but the intake will fit off a 400 engine right to a 351m
Thanks
Feb 16, 2014 | 02:10 PM
will a 351 Cleveland intake fit? or is the 400 wider?
Feb 17, 2014 | 09:11 AM
No the 351m and 400 are wider than a 351C. You'd have to get adapter plates made to take up the difference.
Feb 17, 2014 | 10:26 AM
ctubutis
This might help:
Yes they are externally balanced hence the difference...
Dave2488
Jun 3, 2012 01:06 PM
lucky no. 7
27
Dec 20, 2007 04:03 PM
385seriesHemi
Mar 19, 2007 07:26 PM
qikbbstang
Jun 18, 2001 07:43 AM
