RedHead Steering Box Leaking
Old Feb 23, 2022 | 12:43 PM
R&RFord's Avatar
R&RFord
As the title suggests, my RedHead steering gear box is leaking at the input shaft. It isn't horrible, but the frame horn is wet with fluid and checking the level, I am going to have to start feeding it soon.
The gear box is otherwise performing well. It has been on the truck just shy of 3 years, so I am not thrilled at having to mess with the gear box again, but you do what you gotta do.
So, thoughts on moving forward...
Can I replace the leaking seal/s myself? Send it back to RedHead, or try Blue Top? Other outfits that folks have used?
Old Feb 23, 2022 | 08:23 PM
sandymane's Avatar
sandymane
I just installed a Redhead. Mine was leaking from the line connections because I didn't put the O rings in. I have since installed them and all is well. I don't like the warranty since it doesn't cover shipping or labor. So in your case you might be even on cost if you bought a new one as opposed to sending yours to them for repair. I suggest you call them and see what suggestions they can offer. They were helpful when I called about buying one.
Old Feb 24, 2022 | 07:07 AM
Scndsin's Avatar
Scndsin
Originally Posted by sandymane
.... I don't like the warranty since it doesn't cover shipping or labor. So in your case you might be even on cost if you bought a new one as opposed to sending yours to them for repair..
Could you go into detail about this? That just doesn't sound like it should be anywhere close to equivalent.
Old Feb 24, 2022 | 01:35 PM
diggerrigger's Avatar
diggerrigger
Bear in mind that these steering gear boxes will fit in a USPS Flat Rate Medium box. It'll ship for about $15. I shipped my core to Blue Top in one of these boxes.
Old Feb 24, 2022 | 01:51 PM
sandymane's Avatar
sandymane
Redhead charged 30-35$ for a shipping label to return my core. I thought Redhead had a special price since they had an account with the shipper.
Old Feb 24, 2022 | 02:58 PM
diggerrigger
The Blue Top is shipped in a box of the same dimensions as the medium flat rate. It barely fits and is held securely by injectable foam. So using the same foam makes it easy. If I didn't have the foam packaging I would have sent the core back in a beefed up large flat rate box for $20.
Scndsin's Avatar
Scndsin
Originally Posted by R&RFord
...Can I replace the leaking seal/s myself? Send it back to RedHead, or try Blue Top? Other outfits that folks have used?
Been a while since I looked into red/blue boxes, but thought mods were internal, I would guess seals the same as original or is that modded too?
Old Feb 24, 2022 | 03:00 PM
SFaulken's Avatar
SFaulken
Should be, yes. Has been on every redhead box I've had.
Old Feb 24, 2022 | 03:02 PM
diggerrigger
IIRC, both Red Top and Blue Top are located in rural areas. Maybe they don't have free USPS pickup and rely on UPS or FedEx. With those two, $30-35 is a good price as someone without an account could spend twice that.
Old Feb 24, 2022 | 03:08 PM
diggerrigger
It's possible that the input shaft seal is not a difficult job. When I read over the process of replacing the Pitman arm seal, I decided I wanted no part of it. It was expensive to blow off that repair but I'm okay with replacing the whole unit. It is a better than stock unit.
Old Feb 24, 2022 | 03:14 PM
R&RFord's Avatar
R&RFord
So, several companies make seal kits, including just input shaft seal kits, so I bought one by Gates. Got it installed today, and it seems fine so far. I will provide an update on how it works out.
As far as the work went, I decided to give it a try with the box still in the truck, which worked out. There is a dust shield, snap ring, and seal. It was like replacing an axle seal. The dust shield and seal are press fit, so just had to puncture them and then pull them out. The biggest pain was getting the snap ring out, which was just a matter of patience.
Old Feb 24, 2022 | 10:06 PM
R&RFord's Avatar
R&RFord
The seals that came out were identical to the stock replacement parts I purchased.
Old Feb 25, 2022 | 04:02 AM
TooManyMIce's Avatar
TooManyMIce
Hopefully they last longer this time!
z1pp0
May 23, 2010 12:01 AM
ExtrmZ
Mar 1, 2010 03:12 PM
cruzer23
Jul 24, 2007 11:20 PM
weverette1
Feb 2, 2005 02:57 PM
geo_bar
Apr 12, 2003 08:57 PM
