Engine number identification
Old Feb 22, 2022 | 10:14 AM
Dan Dare's Avatar
Dan Dare
5th Gear
I'm getting ready to re-build a Ford 300-6 engine for a special project, but I'd like to know what year it is before I start ordering parts. Before we go any deeper, the engine is not in a Ford chassis, so decoding the VIN is not an option.
Apart from a casting# (D5TE6015AA) located on the lower right side of the block casting above the sump to block seal, there is no apparent engine number. Apart that is, from a number stamped (could be cast) into the alternator mounting bracket which reads: E51E10239AB
I have a few more questions for the forum regarding this engine, but establishing the year and any other details these numbers reveal is a good starting point. Thanks in advance
Old Feb 22, 2022 | 10:19 AM
Dan Dare's Avatar
Dan Dare
5th Gear
300-6 engine
Here's the engine in question. No engine number?
Old Feb 22, 2022 | 12:12 PM
77highboy77's Avatar
77highboy77
Based on this thread, there should be an additional number series after the block engineering number you've included. This will show you the date the block was cast. This doesn't mean that's the date that the block was used, it might have been sitting on the shelf for a long time, but it is the closest thing you'll be able to use to determine the date of the engine. Based on the engineering numbers you've provided, the block design was a 1975 engineering design (D for 70's and 5 for 75). The alternator number however would be a 1985 (E for 80's and 5 for 85). This either means the alternator bracket was replaced at some point, or Ford was potentially using 1975 designed blocks all the way into the mid-80's.
Old Feb 22, 2022 | 12:21 PM
dlburch's Avatar
dlburch
there is an E1TE-6015-AA, so that puts your block between '75 and '81.
Old Feb 22, 2022 | 02:45 PM
Dan Dare's Avatar
Dan Dare
5th Gear
Engine number Identification
2 pics here - the first one shows the cast in block I.D. followed by a long space before the Ford logo. Looking closely after a good wire brushing, you can see inthe 2nd pic, a very feint rectangular outline in this space, but there is no evidence of any numbers either stamped ot cast into this rectangle.
Are there any other distinguishing marks on the block (or even the head which appears to be of the same vintage but I cannot verift that) ?
Old Feb 22, 2022 | 03:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check out this thread:
https://www.ford-trucks.com/forums/1...date-code.html
As you can see, there's a lot of discussion when it comes to Ford casting numbers.
With the exception of certain "high performance" engines (hi-po 289, Boss 302, Boss 429, etc.) Ford never stamped an actual engine number on the block. They only had casting numbers for the casting itself, casting date, foundry ID etc.
Old Feb 22, 2022 | 03:30 PM
dlburch's Avatar
dlburch
here is an example of a block with a date code...not sure if ALL blocks had a date code...
https://www.ford-trucks.com/forums/1...l#post11836077
Old Feb 22, 2022 | 03:51 PM
Dan Dare's Avatar
Dan Dare
5th Gear
Great info from everyone - thank you.
Based on the contributions, I feel pretty confident in saying my engine is 1985 manufacture based on the numbers on the alternator bracket (E51E10239AB)
I'll start a new thread for other topics - thanks everyone!
Old Feb 22, 2022 | 09:19 PM
dlburch's Avatar
dlburch
I assume you meant 1975? I wouldn't base the engine year on a bracket...
GoodBones
Jan 21, 2019 09:47 AM
gearhead351
Aug 28, 2007 05:20 PM
lavcheech
May 21, 2005 02:56 PM
topo4u2
May 21, 2002 09:18 PM
