DTC P054F Question ?
Old Feb 21, 2022 | 07:47 AM
DaveyMac's Avatar
DaveyMac
Exclamation DTC P054F Question ?
Yesterday stop for fuel, Started up truck and got a P054F and CEL as per Idash.
Up until then No Problems, truck is 2021 with 4.700 miles on it. Cleared code and I'm waiting to see if it comes back, Also Ford Pass has the code but that wont clear ?
Can anybody give more insight on this ?
Found this bit of Info: Ford/ P054F
Old Feb 21, 2022 | 10:13 AM
Overkill2's Avatar
Overkill2
Cause:
  • Intake air system restriction
  • Vacuum leaks
  • Exhaust system restriction
  • Engine mechanical concern
  • Sludged throttle body
  • Damaged intake throttle actuator
Your truck is too new to have a sludged throttle body. Does it ever act goofy when on the throttle for a possible intake throttle actuator?
Did you check your air filter?
I would hope you would not have any mechanical issue with such a new 6.7.
A vacuum leak could be a concern though.
Do you monitor fuel pressure on the iDash? I monitor my DFCM ( the primary pump on the frame rail) in mine. Yours would be from the in-tank fuel pump in the newer models.
Old Feb 21, 2022 | 01:06 PM
DaveyMac's Avatar
DaveyMac
For the life of me I look through idash menu and I cannot find DFCM or am I missing something.
Old Feb 22, 2022 | 05:19 AM
senix's Avatar
senix
DFCM won't be on the idash. Fuel pressure would be.
Take the truck in. As long as the ford pass shows the DTC they should address it.
Check to make sure it has an air cleaner installed and the box is mounted (lid) correctly.
Old Feb 22, 2022 | 07:21 AM
DaveyMac's Avatar
DaveyMac
I got a appt. for Thursday, Service Mgr. said there is an update to PCM for my Vin that will address this.
I will report back.
Old Feb 22, 2022 | 01:15 PM
speakerfritz's Avatar
speakerfritz
I would drain some fuel into metal can and do a flash test.....you can google youtube on how to do the test.
also, double check any additives to make sure they do not contain alcohol or methanol.
are you running winter diesel? some winter diesel has excessive % of kerosene
Old Feb 23, 2022 | 10:53 AM
DaveyMac's Avatar
DaveyMac
I would think its winter diesel, I 'm in Upstate N.Y. I'm running Hot Shot's Anti-Gel. My Dealers service dept. does a lot of trucks and is familiar with this code he believes this will be corrected with a PCM update. going tomorrow for the update.
I cleared the code & it has not come back, all thou its hard set in PCM history.
Old Feb 23, 2022 | 12:02 PM
speakerfritz
that’s what it sounds like to me. Winter diesel and more bottled anti gel and other light additives on top of it.
me personally would only add more lube additives to winter diesel.
gas in the fuel will also cause the error.
Old Feb 24, 2022 | 04:17 PM
DaveyMac's Avatar
DaveyMac
***UPDATE*** I had the PCM TSB Update done today, All the codes Even in Ford Pass App are gone. Now Ill drive around for a couple of drive cycles & wait to see if it's gone for good.
Old Feb 25, 2022 | 04:08 PM
Overkill2's Avatar
Overkill2
I'll post pics up if you can't figure it out. Let me know.
Old Feb 25, 2022 | 04:09 PM
Overkill2's Avatar
Overkill2
That's good news. Nice follow up. Some come here and don't follow up after they ask a question.
Old Feb 26, 2022 | 06:41 AM
DaveyMac's Avatar
DaveyMac
No problem, you know the way it goes with Fault codes "Gone today Back on tomorrow"
I found fuel pressure rail monitoring, but not lift pump pressure in Idash.
Old Feb 26, 2022 | 06:49 AM
The Bone's Avatar
The Bone
I would think upstate NY would have anti-gel in there fuel already. I would stop using it and see what happens. If they didnt use anti-gel it would gel in the hose on the pump. You may be over-dossing the fuel.
Old Feb 26, 2022 | 10:20 AM
Overkill2's Avatar
Overkill2
I run K100 which has anti-gel properties. I wouldn't run my truck without it.
Old Feb 26, 2022 | 10:21 AM
Overkill2's Avatar
Overkill2
@DaveyMac
Here's a screen shot of my iDash.
It shows REGEN Status (OFF/ON) ; DPF soot load percentage ; EGT1 ; EGT4; OLM; ECT ; Fuel level percentage and Lift pump pressure PSI.
island eddie
Nov 5, 2021 08:04 PM
khpony
2004 - 2008 F150
Aug 22, 2021 12:53 PM
Notplayn
6.4L Power Stroke Diesel
Jan 10, 2014 08:12 PM
VFTB
13
Sep 3, 2008 09:33 PM
Carlos2
1997 - 2003 F150
Aug 3, 2007 09:31 PM
