Ok, So I'm apparently trying to find the impossible for my truck. I have a 1988 F350 cclb dually 4x4 with a 7.5l W/air conditioning and I need a fan shroud. If anyone can point t me in a direction to finding one would be greatly appreciated or if anyone has the OE part number for me to try cross referencing would be great. Thanks for any help or input on this!
I found that one too but if you read the vehicle fitment details it says its for non A/C trucks even though the title says it is for with it. Thats why i was hoping to find an OE part number to compare it to the listed compatible part numbers.
I imagine a non ac truck has a small fan possibly, maybe just the "reach" from the water pump is different distantce, and one thing for sure tho is the radiators are usually smaller in a non ac truck and that size difference may be thickness, height, etc... which most fan shrouds attach on top and bottom. if the radiator is the same height, it may be worth getting a the shroud linked because it may just be a matter of how deep into it the fan sits or it maybe something easily adapted. You just need your shroud to cover an appropiate anmount, place the opening in the spot your fan will actually turn, and read enough to actually slightly enclose the fan partially into the opening. The contours or other parts may be different but if you find a junkyard or local one you can get a good idea if you commpare it up.
you can also make one physically if it came to it.
ANything on LMC? universal stuff may be able to be adapted.
I apologize if none of this helps just thinking of things that may be helpful, I have no experiecne with an 88
I haven't found a single one that said it is compatible with a 7.5L A/C truck. I think I'm gonna order the one linked since it's the only one I've came accross that says it fits a 7.5L and go from there. If it fits but I have to do some trimming then that's what I'll do. I've called every junkyard in a 100 mile radius of me and not a single one has one.
www.car-part.com G & B Auto Parts, Inc. USA-VA(Floyd) 540-745-7401
shows 2 for 87 F350 with 460 engine.
and a bunch more in different yards in the 87-96 year range with 460 engine.
Thanks for that info,.I'm going to call them tomorrow and see if they still have it.
Update! So I went ahead and ordered the shroud listed in the comments above and finally got around to attempting to install it. And wouldn't you know it, the non A/C shroud fits just fine! No clearance issues at all. Just like that she's back on the road with the new old clutch fan I found used and new shroud. Hasn't even ran the slightest bit hot yet like it was doing with the electric fans (3 to be exact) someone had installed previously. Thanks for all help everyone!
