maintenance time
Old Feb 20, 2022 | 01:49 PM
nxtdiesel's Avatar
nxtdiesel
maintenance time
I am getting ready to do a drain and refill of the cooling system and the transmission and was wondering if someone could tell me how much coolant I will need and if the transmission drain plug has a sealing washer that I need to replace. This is on a 2017 6.7 with the 6r140.
Old Feb 20, 2022 | 03:42 PM
jimzpsd's Avatar
jimzpsd
Engine coolant (primary high-temperature cooling system loop) 35.1 qt (33.2 L)1 Engine coolant additive (primary high-temperature cooling system loop) 48 fl oz (1.41 L)2 Engine coolant (secondary cooling system) 15.1 qt (14.3 L)1
Yes, replace the sealing washer
Old Feb 20, 2022 | 04:19 PM
nxtdiesel's Avatar
nxtdiesel
Thanks, but I think that is the total system capacity, I assuming I won't get near that much out just draining the radiator, right?
Old Feb 21, 2022 | 11:01 PM
johndeaux22's Avatar
johndeaux22
You won’t get the entire volume out with the radiator drain. With the primary cooling system you’ll be able to drain about 5-6 gallons. I typically drain until it stops, top the system with distilled water (+/- 5 gallons), run it up to operating temperature, drain again, fill with 4.5 gallons of the appropriate coolant - yours might want orange, or yellow; fill with what it had from the factory. With the secondary cooling system, you do the same, just add 1000 MF’s trying to get the drain open - only a 10 jointed midget would be able to open the thing easily. I change mine about every 50k miles, so don’t worry much about getting every drop out.
Redland1
Sep 14, 2018 09:57 AM
menzfamfour
1997 - 2003 F150
Apr 21, 2016 08:30 PM
Avanti
Escape & Escape Hybrid
Jul 16, 2013 01:37 PM
00buck75
Apr 1, 2011 05:32 PM
02GrayPowerStroke
Feb 28, 2010 09:33 AM
