Camper package
Old Feb 18, 2022 | 07:08 AM
Bldrinker's Avatar
Bldrinker
Camper package
Hey guys is this camper package the over load springs and rear sway bar?
Old Feb 18, 2022 | 07:17 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
It's exactly what the description says and I can't explain it any better that Ford can.
crewzer's Avatar
crewzer
Lightbulb
It depends. On most F-250’s (below King Ranch trim), the package includes an auxiliary leaf in each rear spring pack (4 leaves total per pack) plus the rear stabilizer bar.
On most F-350 SRW’s (also below KR trim), the package adds just the rear stabilizer bar to the rear suspension, as the rear spring packs are already five leaves total.
Both trucks typically get stiffer front springs plus VIN-specific camper certification docs. Note the optional camper package does not increase GVWR or payload; it just improves handling when loaded with a truck camper.
The camper package is not available on trucks with 20” wheels. Accordingly, it’s my understanding that it’s not available on new SRW trucks with King Ranch, Platinum, or Limited trims.
HTH,
Jim / crewzer
Old Feb 18, 2022 | 07:19 AM
chadstickpoindexter's Avatar
chadstickpoindexter
It’s the heavier front springs (based on other options), one auxiliary/helper spring leaf in the rear and the sway bar.
Old Feb 18, 2022 | 07:33 AM
Bldrinker's Avatar
Bldrinker
Thanks. That’s what I figured. But auxiliary and stabilizer wording had me wondering.
im going to see if I can add it to my order
Old Feb 18, 2022 | 11:02 AM
edjunior's Avatar
edjunior
I have the camper package on my truck, and I will say this. I do not have to have airbags for my 5th wheel. I had to have the airbags on my last two trucks, but this one sits perfectly level once the 5th wheel is hooked up.
Old Feb 18, 2022 | 11:14 AM
rklavoon's Avatar
rklavoon
I have 20" tires on my truck and added the sway bar after delivery. I have a post on here with all the parts the pieces you will need if you added it afterwards. I tow a 10,000 trailer and it does help with body roll. Some people opted for the Hellwig one, but I am happy with the OEM one (smaller diameter).
Old Feb 18, 2022 | 01:28 PM
KH338's Avatar
KH338
I have that option on my truck and like parts that are added. All except for the away bar that I removed and didn’t need for my situation.
Old Feb 18, 2022 | 03:17 PM
Bldrinker's Avatar
Bldrinker
Dealer said I can’t add it because of the BAP.
Old Feb 18, 2022 | 03:24 PM
4wd6.7L's Avatar
4wd6.7L
Right, because of the 20" wheels that are standard with that package.
HGaither
7.3L / 6.8L V8 Gasoline Engines
Jun 3, 2022 06:41 PM
taycotrains
Feb 14, 2018 01:04 PM
postman524
Nov 4, 2010 07:28 PM
TheDuke
Aug 2, 2005 11:21 PM
Fordfreak1978
Jan 12, 2005 09:57 PM
