1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Smoke everywhere
Old 02-16-2022, 03:34 PM
DuncanB's Avatar
DuncanB
DuncanB is offline
Trailering
Smoke everywhere
2006 f350 smokingAfter an egr delete had some major boost leak problems, fixed it to best of my ability, drove alright for 2 days the. Went to AutoZone to use their scan tool I had a low circuit code for #1 injector, before I got to AutoZone it drove just fine. Then I left leaving AutoZone it start to make a knocking sound and started missing a little, the missing went away and so did the knocking and my boost wasn't getting as high as normal drove it the rest of the way home soon as I pulled in it started to smoke so I quickly shut it off opened hood looked for anything noticable, I check my injector plug for #1 seemed fine, then check my coolant it looked normal as usual, check oil, also full. The smoke came from exhaust and engine bay but couldn't find where exactly it came from any idea what this could be, I think I have learned my lesson not to buy cheap egr parts😭
Old 02-17-2022, 09:45 AM
bwguardian's Avatar
bwguardian
bwguardian is offline
Can we assume this is a 6.blow...
Old 02-17-2022, 11:41 AM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Failed cylinder #1 injector??? 6.0L diesels are old news for me now, but the symptoms you describe point squarely to failed injector seal(s). A "bubble test" will likely get you to your source.
Old 02-17-2022, 02:12 PM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
Have you ever heard of an EGR delete on a 5.4L?
Old 02-17-2022, 03:23 PM
bwguardian's Avatar
bwguardian
No, but I don't assume...as in it could be a transplanted 6.4L, 6.7L, Cummins, etc.
fords/harleys
10-08-2018 04:58 PM
addybeer
6.4L Power Stroke Diesel
38
01-07-2015 08:29 PM
bobbyt89
03-28-2014 12:29 PM
JonArmy
10-03-2011 09:12 PM
devildog12210
08-23-2010 09:40 PM
Quick Reply: Smoke everywhere
