2002 Excursion brake line problem
Old Feb 16, 2022 | 11:08 AM
Jim TN's Avatar
Jim TN
Brake line that goes from the anti lock manifold to rear wheels has sprung a leak where the flexible part attaches to the metal line. Where can I buy this? Rock Auto has two kits with multiple lines but is out of stock on both. Are these lines a problem that will occur sooner or later with the rest of them?
Old Feb 16, 2022 | 01:11 PM
SteveZ's Avatar
SteveZ
I haven’t had to replace mine yet so the best I can do is point you to another thread where different kits were discussed. https://www.ford-trucks.com/forums/1...level-kit.html
your Ex is 20 years old so it is reasonable to assume the brake lines will fail at some point. If you have the money and time it may be worth doing them all while you are are fixing the broken one.
Old Feb 16, 2022 | 01:17 PM
thor363's Avatar
thor363
Picture please, so we can help.
Old Feb 16, 2022 | 03:10 PM
Bently_Coop's Avatar
Bently_Coop
Try these guys:
https://www.sstubes.com/collections/...Excursion-2002
Old Feb 17, 2022 | 11:22 AM
T-wood's Avatar
T-wood
I used the sstubes kit. The one i ordered comes with every hard brake line. It fit well, was well packaged. And the reality is once one line goes the others aren't far behind. Ive had them fail on different Fords and it's always during a good hard stomp on the brakes.
Old Feb 17, 2022 | 02:29 PM
jasonodsky's Avatar
jasonodsky
I used the DORMAN 919295 (Set) Kit; OE FIX Info 4WD from RockAuto. Since they are out of stock, do some googling for a place that has it. It's likely if one line rusted out, you have others that are close to failing. That's why I ordered the full kit. I started only replacing one line and found two other lines with rust that was sketchy.
I was pleased with the quality and they are stainless steel so the rust factor should not be an issue anymore. I only installed the lines to the two front wheels and across the rear axle. Looked like the front to rear line was two pieces to make it easier install without pulling large parts off the truck.
Good luck but it's not too bad to replace them.
Jasonodsky
Old Feb 17, 2022 | 08:44 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
I used the Dorman kit also, my rear line from the master to the rear axel sprung a leak for the second time so I knew it was time to replace them all with stainless . As stated above an easy install.
Jackford
Jul 14, 2022 06:09 AM
spedbugy
1983 - 2012 Ranger & B-Series
Sep 13, 2010 04:41 AM
mOROTBREATH
59
Jun 2, 2010 07:41 PM
nijwnfi
Bronco II
Jul 17, 2005 02:00 PM
Rediranch_too
Oct 8, 2004 02:31 AM
