Code P259F
Old Feb 15, 2022 | 07:33 AM
satz28406's Avatar
satz28406
Code P259F
2019, 47K miles - Merging into heavy traffic on a freeway and the tuck bogged down and went into limp mode. The check engine light cam on and I pulled onto to the shoulder. Shut off the engine, waited a few minutes and restarted. The check engine light stayed on an it drove fine the rest of the way home - 50 miles, with 75% of the miles being highway. Kept my eyes on my gauges and boost and temps are normal. When I got home I pulled the code
Since it seem to run fine after I shut it off and restarted, any issue in resetting the the DTC and driving the truck?
Comments and thoughts:
This is what I found:
https://www.dtcdecode.com/Ford/P259FDescription:This
DTC sets when the VGT command is greater than a calibrated value for the current amount of boost pressure for more than a calibrated amount of time.
Cause:
  • Intake air system leaks between the turbocharger and the intake manifold
  • Damaged MAP sensor
  • Turbocharger actuator is not responding
  • VGT vanes sticking
Old Feb 18, 2022 | 11:11 AM
speakerfritz's Avatar
speakerfritz
Check the underside of your hot side intercooler tube for cracks.
report back.
you may want to look at a few YouTube videos on this subject.
Old May 11, 2026 | 11:19 AM
Lk40hp's Avatar
Lk40hp
Did you ever figure this out?
ranger1385!
6.4L Power Stroke Diesel
Oct 5, 2021 06:28 AM
CowboyUp!
6.7L Power Stroke Diesel
13
Jan 14, 2016 05:46 AM
vectrex
Jun 25, 2012 05:54 PM
PA 6.0 STROKER
Oct 28, 2008 06:40 AM
Fraalan
Feb 27, 2007 02:22 PM
