Chattering noise
Old Feb 14, 2022 | 11:13 PM
BWilcox's Avatar
BWilcox
Chattering noise
I have a 1997 f-350 7.3 with a automatic transmission. A while back I noticed that when I put the truck in any gear(park to drive, drive to reverse and so forth) that it would kind of make a hard knocking sound when it went into gear. And when I let off the gas pedal all the way it will do a hard knock that’s kind of the same like something disengaging and then when I put about half pedal it knocks back in the same way. The past couple days I’ve noticed it get worse and seems to hit a lot harder. Today I was driving it and around 40 MPH and when my foot is at a certain level on the gas pedal a clanking happens like grinding noise almost like gears not lining up and chattering together. It kind of goes away when I give it more gas or let off more. Any help in helping me diagnose would be great! Thank you
Old Feb 15, 2022 | 03:19 AM
z31freakify's Avatar
z31freakify
Check the U-joints on the drive shaft.
Old Feb 15, 2022 | 07:12 PM
BWilcox's Avatar
BWilcox
@z31freakify I have looked at them and tried moving them and there’s no play at all in them
Old Feb 15, 2022 | 07:48 PM
96 OBS's Avatar
96 OBS
Just to be clear… jack the rear end up put the truck in neutral and move the shaft back and forth. Just to make sure. Other than that, mine had a bit of play between the trans and diff making a similar noise. Mine was manual but could be similar
Old Feb 15, 2022 | 08:16 PM
BWilcox's Avatar
BWilcox
Okay I will try that and let you know, thank you
Old Feb 15, 2022 | 08:48 PM
96 OBS's Avatar
96 OBS
No problem. Yeah if theres any resistance on the driveshaft (tires on the ground) it has to be perfectly level to check u joints like that. Always best to lift the rear end. Just for fun Here’s a pic of a u joint I lost last night. Happy vday
Greenie326
2015 - 2020 F150
Oct 9, 2020 05:13 PM
Greenie326
2015 - 2020 F150
Jan 24, 2018 05:05 PM
JHollahan
General Automotive Discussion
May 4, 2017 10:48 PM
bush32
2004 - 2008 F150
Jan 20, 2009 10:56 AM
