It's back
Old Feb 14, 2022 | 03:57 PM
HOTROD101's Avatar
HOTROD101
It's back
little while back I lost spark on my 1995 F150 5.0 a new module and PIP sensor restored my spark. My speedometer and dome light quit working and a new fuse took care of that...so I thought. I had to replace to fuse again, it still works but my spark is a orangish yellow
Color. It use to be a strong blue. Any one have any ideas.....
Old Feb 14, 2022 | 06:45 PM
torq'ta 5 8's Avatar
torq'ta 5 8
How old is coil? or do you know, codes?
how to -->Part 1 -Ignition Coil Test -No Spark No Start Tests (Ford 4.9L, 5.0L, 5.8L)
Old Feb 14, 2022 | 07:45 PM
HOTROD101's Avatar
HOTROD101
The coil is new and there are no codes showing. I backprobed the power side of the ignition coil to ground with a self powered test lite, with the coil disconnected and the ballers. Both battery terminals were disconnected. Also the PCM and ICM and distributor unplugged. I really need a good electrical diagram to trace the wire so I can start unplugging connectors....
Old Feb 14, 2022 | 08:12 PM
torq'ta 5 8
maybe this
Old Feb 14, 2022 | 08:55 PM
HOTROD101's Avatar
HOTROD101
Thanks a bunch, tomorrow I am going to dig into the ignition switch again. I replaced that about a month ago. I hope Autozone has to do a parts warranty. I really think that today's auto parts are being mass produced to quick. It seems like no one cares about quality products anymore.....Thanks again
Old Feb 14, 2022 | 09:37 PM
wwhite's Avatar
wwhite
What kind of coil?
Probably not a Motorcraft.
Old Feb 15, 2022 | 03:16 AM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by wwhite
What kind of coil?
to be fair I would be hard pressed to give the light of day to a motorcraft igniiton module from duraspark 2 cars.. Lol... But yes a motorcraft coil for that vintage is wise
infact, i felt bad replacing my OEM coil with a oreillies because the coil nub for the wire was.. well.. zapped down it was lose and not a consistent shape. carbon tracked inevitably too
Old Feb 15, 2022 | 08:23 AM
HOTROD101's Avatar
HOTROD101
Both the coil and the module are duralast. I don't think neither of those are my problem. I am at C101 now and I do need a pin out if anyone has one. I have several wires that I need to trace. I am beginning to think that a field mouse has been under my dash. I should have threw a few bars of deodorant soap under the dash when I fist got the truck. Maybe this would not have happened. It worked in a few cars that I have restored. If anyone has a C101 pin out and a ignition switch pin out I would really appreciate them...
Old Feb 15, 2022 | 12:56 PM
torq'ta 5 8
c101 male/female
Old Feb 15, 2022 | 12:58 PM
torq'ta 5 8
Was your ICM one of these below
pic courtesy of rla2005
Old Feb 15, 2022 | 06:03 PM
HOTROD101's Avatar
HOTROD101
It was a motorcraft 5f16c...now it is duralast f139 ...I think that is same as standard..Circuits 648, 264, 360, 355, 351, and 359 are shorted to ground some where. I would like to find a good diagram so that I can chase these circuits. Pictures of connector locations will help since I will be unplugging connectors to find which way the wires run under my dash. Thanks for all your help....
speakerfritz
Nov 23, 2021 12:51 PM
Greywolf
All Things Towing
Apr 26, 2009 08:35 PM
rprice32
15
Nov 4, 2004 08:34 AM
wezol5484
General Automotive Discussion
May 20, 2004 01:51 PM
idoher69
17
Dec 5, 2003 08:13 PM
