Originally posted by mcanik Did you check your PCM Relay and/or fuse for it?
Both are located at the engine compartment fuse block. the fuse is in position I (9) and is 20A.
Hope this helps
Dan
Check your fuse panel guide in your owners manual for exact locations or refer to the plastic cover on the engine compartment fuse panel. There is a diode according to my wiring diagram tied into the PCM (EEC). this is fuse-like in appearance and is located at that fuse box in position L (12). Could be bad as well.
This all may be just a shot in the dark, but it may help you
thx again mcanik i will get those fuses tommorrow and get back to u i know theres power going into the coil im wondering if the condenser is screwed i had 1 laying around i put it on still nothing dont no if that 1 was gone to or not
geesh i would of been beter of just bringing it to a mcanik but im this far now might as well go all the way
When this comes up, I always like to point people in the direction of the Ignition Control Module. They have a tendency to fail without warning and give the symptoms you describe. Most parts places have the ability to check them for free.
Do a search(www) on the ford ignition module and you'll find out how to check it (and the pip sensor) without buying the manual -- where ever you are getting your fuses from you'll probably find the manual.
Check for +12v at each relay -- if its below ~10v(dc) or so and the preceding one is +12v then you may have a bad relay. If you hear the fuel pump clicking and our getting +12v measured at the relays probably not relays/fuses. (Key on) .
I had this problem this past summer turned out to be the ignition control module and pip sensor.
