Massive oil consumption
Old Feb 14, 2022 | 12:13 AM
Hammr412's Avatar
Hammr412
I changed my 15w-40 oil in November before driving from Utah, to Texas, and pulling a 32' back to Utah. This is the 3rd time in my knowledge of pulling out significantly less oil than 15 quarts on an oil change. I can tell when it's been consuming oil because the truck will shutter start and idle rough. Is this oil consumption bad injector O rings?
Old Feb 14, 2022 | 08:40 AM
farmert's Avatar
farmert
If you have the OEM fuel system, pull the fuel filter and see if it is black and slimy. That is on sign of leaking injector o-rings. Another test is to free rev the engine. If it revs to 1800 rpms then stumbles and slowly builds rpm while billowing white smoke, this points to bad o-rings.
Old Feb 14, 2022 | 01:25 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Yes, you could have worn external orings or even worn internal orings.
Old Feb 14, 2022 | 04:46 PM
Hit Man X's Avatar
Hit Man X
So you never checked it driving that far? No idea of how far down on oil?
You may have leaks compounding the issue.
Old Feb 15, 2022 | 07:55 PM
96 OBS's Avatar
96 OBS
Oil cooler tube is also another very common leak point
microdevil45
52
Jul 21, 2015 10:44 PM
A/Ox4
66
Nov 3, 2013 09:04 PM
ASE
Aug 30, 2004 01:53 PM
mstepchinski
16
Jul 12, 2004 02:25 PM
86bronco2jeff
Oil & Lubrication
Mar 25, 2003 11:32 PM
