ZF5 whir?
Old Feb 13, 2022 | 11:18 AM
7.3noob's Avatar
7.3noob
ZF5 whir?
my zf5 is making a whirring noise when the engine is running, and it stops when I hit the clutch pedal, maybe throwout bearing?
squeak is me hitting the clutch, the noise goes away as I hit it
so far this truck has lots and lots of little noises that concern me, currently ive gotta chase down a coolant leak (passenger front tire has coolant running down it)
other than that its 2 rims, 6 tires and a bed, mirrors and itll be good to go
Old Feb 13, 2022 | 11:38 AM
Hit Man X's Avatar
Hit Man X
This a 7.3DI or IDI?
Drop inspection plate and check to see if you have a dual mass flywheel problem, if equipped. I posted pictures of the back and front of a SMF for reference on the 7.3DI section.
Tough to tell on audio from compressed video, but sounds like just depressing the clutch to me aside from squeak. Also, spend $20 and buy new Ford bushings for your pedal box. Quick rebuild and the clutch works better...gravity flush the hydraulics too.
SFaulken's Avatar
SFaulken
That's a pretty classic sign of a Throwout bearing thats dying, yes.
Old Feb 13, 2022 | 12:01 PM
7.3noob's Avatar
7.3noob
other than the squeak the clutch is flawless
im thinking its throwout bearing as well
7.3 idi
what is a dual mass flywheel?
Old Feb 13, 2022 | 12:18 PM
Hit Man X's Avatar
Hit Man X
Mine makes all sorts of sounds but it is a single mass fly with a 7.3DI and clutch kit with maybe 40k on it. Last TOB I heard was real bad. Guess I drive too much old stuff.
If you do need a clutch kit, the Luk kit is very durable behind these. It runs about $300 plus ffreight. I read a while back about 7.3DI kits being used behind the IDI. A search on Oilburners will give all needed detail.
On the bushings, you would be surprised at the wear with age.
Old Feb 13, 2022 | 12:27 PM
7.3noob's Avatar
7.3noob
hopefully I dont need a clutch kit, can I just replace the throwout bearing?
Old Feb 13, 2022 | 12:33 PM
SFaulken's Avatar
SFaulken
Yes, but you've got to drop the transmission to do it anyway. If I've got to drop a transmission, unless I *know* the clutch is very low mileage, I replace the clutch, just to save me the trouble of having to drop the transmission *again* when the clutch inevitably wears out.
Old Feb 13, 2022 | 12:39 PM
7.3noob's Avatar
7.3noob
I get your point, I dont wanna drop it a second time, but the money for a clutch kit is more than I got, as I get work (Im starting my own company, this is a work truck) i will be able to afford a clutch kit in a few months, currently ive gotta worry about it being road legal, getting tires and a bed
Old Feb 13, 2022 | 02:28 PM
Hit Man X's Avatar
Hit Man X
Drive it like that. You would be a dummy not to replace it all at once. Do not create work.
Check rear diff level and the breather hose instead.
Old Feb 13, 2022 | 02:50 PM
7.3noob's Avatar
7.3noob
yup, going to check the diff fluid as well, gonna do trans fluid soon, hopefully tomorrow
if the bearing goes out, neither me or my dad (who will spend the most time driving it) is scared to drive it without a clutch
Old Feb 13, 2022 | 03:32 PM
Hit Man X's Avatar
Hit Man X
Easy to gravity bleed it. Open master, open slave and let drip. It holds very little so keep eyes on it! I almost ran mine dry like a fool.
Brake flush also very smart and fresh lines. My 01/92 4.9 had OG lines when acquired. Scary for a 320k truck.
High side PS lines to pop at random on the 7.3DI with the CII pump. They are maybe $20 new.
Old Feb 13, 2022 | 03:35 PM
7.3noob's Avatar
7.3noob
at some point I will do that as well, making a list of parts I need, from strike bolts and wiper blades to bushings in the front end
Old Feb 13, 2022 | 03:39 PM
Hit Man X's Avatar
Hit Man X
You have a dually correct? I put 245/75R16s on mine instead of those hard to find 215s. Far more choices available in D and E codes.
Wipers always smart!
Old Feb 13, 2022 | 03:43 PM
7.3noob's Avatar
7.3noob
mine are 235/85r16, and yes its a dually, missing 2 rears tho
61Redneck
Sep 28, 2021 03:28 PM
maxride
74
Jan 31, 2016 07:43 PM
reamer
21
Feb 8, 2014 09:26 PM
mattmayo
Jan 29, 2010 03:09 PM
atomicexhaust
Apr 20, 2004 06:33 AM
