ive been hearing a noise coming from my tranny/clutch it sounds like running water sometimes it stops when i push the clutch pedal sometimes its always making the noise- the noise doesnt accel/decel it is just there. what is it?
i appreciate any info you can offer thanks for reading this
If you step on the clutch and put in gear does it stop immediately?
My m5od has some input bearing noise
Check your fluid-easy to do-the m5od has a known slow leak tendency
sorry for the delayed response. yeah thats exactly what mine is doing, it also has a slow leak, i just recently changed the fluid in it but i dont remember if it stopped i only notice it when its there. thanks for the help its much appreciated
