Factory bed step
Old Feb 8, 2022 | 12:44 PM
Romark's Avatar
Romark
Factory bed step
When I had my 2015 F150 4x4, it came with these retractable bed steps which made access to the front of the bed real easy. Now that I have a F250 4x4, the bed is quite a bit taller to the point that it will be impossible to access the front of the bed from the side. Is there anything available I can bolt to the frame to solve my problem? I do have the AMP retractable running boards too. I can't seem to find anything.
Also, It's amazing how much these trucks have changed. I recently got my dads 2002 GMC 4x4 Duramax 2500 to use as a work truck. Basically its the same truck as my 2022 F250. Both 4x4, both 3/4 ton. The height difference is amazing. I can reach over the bed side to touch the bed on the GMC. Not even a chance with the F250
Old Feb 8, 2022 | 12:51 PM
Pugga's Avatar
Pugga
Look at the AMP Bed Step and I believe Bestop makes a version also. They're a spring-retracted step that mounts in front of the rear tire, specifically for access to the front of the bed. Real Truck usually has them listed and I believe AutoAnything sells them as well.
Old Feb 8, 2022 | 12:58 PM
-David-'s Avatar
-David-
https://www.ford-trucks.com/forums/1...r-ccsb-kr.html
See post #12 AMP Research Bed Step 2
Old Feb 8, 2022 | 01:02 PM
NedFletcher's Avatar
NedFletcher
I thought I recall seeing somewhere where the steps from the f150s would fit on the 350s. I took the steps off my 16 f150 to put on my 350 whenever it comes in if they fit.
Old Feb 8, 2022 | 01:12 PM
Romark's Avatar
Romark
AMP doesn't make it for the F250. Ford is not listed as an option on their website
Old Feb 8, 2022 | 01:21 PM
Pugga's Avatar
Pugga
https://realtruck.com/p/amp-research...ord/f250/2021/
They just haven't updated their catalog to include the 2022's. They have them listed through 2021.
Old Feb 8, 2022 | 01:27 PM
Romark's Avatar
Romark
That's strange. AMP's web site didn't show Ford as an option. Dang, they are proud of them though!!!
Old Feb 8, 2022 | 01:56 PM
Poncho450's Avatar
Poncho450
I’ve had both brands. I know that on my 2016 F 250 Bestop was considerably lower cost than AMP for basically the same step.
However, once the current generation SD came out Bestop was pretty slow on the draw to update so I had to move to AMP. So far I’ve used that same step on 4 of the current generation trucks.
It may be worthwhile for today’s shopper to compare prices. But I have the rear bumper step, not the bedside step. The same step has been on a 2017, 2019, 2020 and the current 2022.
Old Feb 8, 2022 | 04:02 PM
Sledfan600's Avatar
Sledfan600
The Bedstep 2 does fit a 2022 F250. I put them on both sides of mine. They did have the wrong linkage packaged in mine but sent the correct linkage after I contacted customer service. Everything works as expected.
Old Feb 8, 2022 | 04:16 PM
Supra's Avatar
Supra
This was a big sticking point for me! I reach in the bed of my truck constantly both work and play. I did the factory extended running boards which are not available in all trims and packages. I also did the optional $330 Bed Step and the standard Lariat tailgate step. I ended up with Lariat CCSB Ultimate but no sport or tremmor package. Just built last week and awaiting delivery about 2-19
Old Feb 9, 2022 | 04:30 AM
knaffie's Avatar
knaffie
I have the Amp Research 75313-01A on my 2022 Super Duty. It bolted on in about 10 minutes. I love it. Super easy to move up and down and makes getting in the bed effortless. I won't own another truck without a step like that.
https://www.amp-research.com/product...-f-250-350-450
Old Feb 9, 2022 | 11:31 AM
MagicMtnDan's Avatar
MagicMtnDan
I added the Amp Research side step on my 2021 Super Duty so I can reach into the bed and access the 5th wheel hitch easily.
Here it is in stowed position...
sgettin
20
May 27, 2024 08:09 AM
Brett Bednar
Jan 17, 2022 10:24 AM
srkr
Mar 13, 2017 12:25 PM
SeaCarr
Apr 29, 2016 03:35 PM
