2002 Excursion
Old Feb 5, 2022 | 10:00 AM
mattbo505's Avatar
mattbo505
2002 Excursion
Hey guys looking for some help troubleshooting an issue. Just recently picked up an 02' Excursion and there's an intermittent clicking noise from behind the dash no rhyme or reason and sounds like a relay to me sometimes when it clicks it will flash the climate control lights. I have tried to isolate it to what is affected by turning off the climate control screen, but it still clicks? Everything works fine or else i'd probably be able to tell what is causing it.
Thank you for any input you can give.
Old Feb 5, 2022 | 10:05 AM
thor363's Avatar
thor363
If it's repeats rather quickly, it may be LED's were installed and the multi-function switch needs to be replaced.
Also if you have LED's the flasher relay needs to be replaced. That was my symptom when I moved to LED's (both parts)
Old Feb 5, 2022 | 10:07 AM
mattbo505's Avatar
mattbo505
Ahh probably so the PO installed LED's everywhere some flicker and some stay illuminated the turn signal also blinks fast as if a bulb were out, but there aren't. Multifunction switch? as in the entire piece or something different?
Old Feb 5, 2022 | 10:20 AM
mattbo505's Avatar
mattbo505
Would this also affect the headlights? They seem to be intermittent as well. Turning them on and nothing, but I have parking lights and fog lights.
Old Feb 5, 2022 | 10:29 AM
thor363's Avatar
thor363
Try reversing the polarity of the connector for the headlights...one at a time.
Old Feb 5, 2022 | 10:30 AM
thor363's Avatar
thor363
No. ...but the multi-function is the turn indicator/wipe washer stalk.
Old Feb 5, 2022 | 10:40 AM
mattbo505's Avatar
mattbo505
Are you talking about behind the switch itself or elsewhere? im not to sure i understand where you mean?
Old Feb 5, 2022 | 10:43 AM
thor363's Avatar
thor363
At the bulb connector
mattbo505's Avatar
mattbo505
Nix that they are not LED head lights. I have a decent mess to sort through here.
Old Feb 5, 2022 | 11:06 AM
thor363's Avatar
thor363
See if the clicking is coming from the flasher relay. That one is an easier fix.
Easy to test for power at the headlight bulb socket also.
Old Feb 5, 2022 | 11:11 AM
mattbo505's Avatar
mattbo505
For the clicking check will do.
I just messed with the headlights some checked fuses all good went from low to high beam they turned on and back to low beam on no problem.
Old Feb 5, 2022 | 11:21 AM
thor363's Avatar
thor363
If I recall it's between the column and the mid, basically past your right knee. It's also where the code for the door is located and that's even more well hidden.
Old Feb 5, 2022 | 11:51 AM
thor363's Avatar
thor363
Old Feb 5, 2022 | 12:10 PM
mattbo505's Avatar
mattbo505
Awesome this is a great head start thank you for your help i will let you know what i find out.
Old Feb 11, 2022 | 07:19 PM
mattbo505's Avatar
mattbo505
So I replaced the Multifunction switch only to find that didn't solve the rapid flashing. so I swapped back to the old one since it was labeled with a build date of 2016 and returned it. I bought an "LED" relay and replaced the flasher relay fixed the rapid turn signal flashing. I am still having a hard time determining what the clicking noise/flickering climate control screen is.... maybe another relay?
