Not sure how many blades are in mine, but when I got my 04 EX (Dec 2017) the multifunction switch was missing the rear window wiper control. I got the correct one from Rock auto. Plugs are the same.
Tasca part came in (they had to order from another Ford dealer). Dash had been apart for a while since I don't like taking things apart twice. New LED flasher works perfectly with the new multi-function switch, and another issue I had with my rear LED's is also solved.
Thanks guys (yeah especially you Pirate) for the info. I'd have never believed that the multi-function that worked just fine with regular bulbs was also the cause of not being able to get the rear stop lamp LED's working correctly until today! ...so that solved two problems.
As for the Novita EP27 it fits fine under the cover once installed for those that had heard otherwise.
