Master cylinder bench bleed
Old Feb 4, 2022 | 04:13 PM
jstihl's Avatar
jstihl
Can anyone recommend the best way to bench bleed a master cylinder. I've seen where some people say that most of the part stores come with a little hose kit to bench bleed but I got a motorcraft and it did not come with anything. Is the hose kit with all the adapters a good way or I also noticed that you can do this with a large syringe that's made for bench bleeding. Want to do this right and be done with it so hoping for some suggestions, or any tips and tricks, thank you
Old Feb 4, 2022 | 04:20 PM
Walleye Hunter's Avatar
Walleye Hunter
I forget how I plumbed it up but I forced the fluid up through the outlet holes.
Old Feb 4, 2022 | 04:30 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Watch here starting at 35:30
IVe always had great luck doing the same for a long time.
Old Feb 5, 2022 | 06:06 PM
jstihl's Avatar
jstihl
Originally Posted by KubotaOrange76
Watch here starting at 35:30 https://youtu.be/LpOJuYfNdiU?t=2077
Never seen that before, is that basically the same method you would use to bleed the brakes from the calipers while someone is pumping the brake pedal? I couldn't tell in the video when he was holding his finger on the master cylinder and taking it off
Old Feb 6, 2022 | 03:13 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Last time I bled a master cylinder on the bench I used the cheap plastic Dorman kit, worked great. Plugs go into MC outlets with clear tubing that loops back over into the respective reservoirs. Secure MC in vise and stroke it a few times with a punch or similar tool pushing the rod (takes some effort) and when the bubbles stop it's good. Get the lid on and pinch the tubing with a binder clip or something till you get it bolted up to the firewall. Avoid drips on paint, obviously. Then quickly pop the brake lines into the ports and bleed the system as normal.
Old Feb 10, 2022 | 05:09 PM
jstihl's Avatar
jstihl
Thank you aawlberninf350, I will probably go this route. Just wasn't sure if using the syringe was a better method or not. I was probably reading to far into this but did read some nightmare stories about people not being able to bench bleed the master cylinder properly, I will move on using the KISS method. Thank you guys for your input
moejr
Aug 27, 2020 10:37 AM
samahi72
Dec 28, 2006 03:24 PM
jfor26
Jan 13, 2006 03:32 PM
Luanas78
Sep 18, 2004 04:37 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
