1997 F150 4.2 temperature gauge stays cold or drops
My temperature gauge on my 4.2 f150 goes south just a little when i turn on the key and stays there never going up till I turn it off. What could be the reason? I have replaced both temp sensors in front top drivers side and the thermostat and still sqme problem...
I am at my wits end and about ti sell it as is because of the problem
Faulty temperature sender, faulty instrument cluster (gauge and associated circuitry), or faulty (open) wiring from the sender to the cluster.
Disconnect the sender, turn ignition to RUN and see if the gauge reads full cold. If so, connect a jumper between the two pins of the connector (wire harness side). Gauge should go to full hot. If it does not, the issue is either the 2nd or 3rd possibility and more detailed troubleshooting with a meter is needed.
Just so I know if I replaced the correct thing is the Sender the sensor looking thing just behind and to the right(drivers side) and slightly above where the thermostat is?. And when changing it there would be coolant behind it? I get so many different answer to the location of the sender on this '97 4.2 that I an so confused m
I give up and selling this truck because
There are three possibilities:
bowhunter96
09-15-2021 07:05 AM
Kurt Canison
General Automotive Discussion
10-28-2018 05:47 PM
1explorer
02-05-2003 06:03 AM
