Sponsored by: Real Truck
Gauge Recommendations.
Old Feb 2, 2022 | 07:18 PM
yyyames's Avatar
yyyames
My 99 7.3 is pretty much stock other than a turbo back exhaust, cold air and a lift. Its my first diesel and I was wondering if I could get some recommendations on a simple digital monitor? Im hoping I can get something that shows everything I need instead of pillar gauges. Thanks in advance!
Old Feb 4, 2022 | 07:22 AM
Tumbleweed1972's Avatar
Tumbleweed1972
If you're runnig a stock truck and don't d oheavy hauling then the stock gauges will be fine. If you're putting a tuner on it or you haul heavy stuff all the time you'll want a Pyro, Trans Temp and Boost gauge.
Old Feb 4, 2022 | 10:33 AM
kengarchow's Avatar
kengarchow
tuners that connect to the old port often have gauge functions with many options, they use the OEM sensors. not sure what read on the 99 but my 06 has plenty of info available. u don't have to use the tune function. i even use mine as a screen for my back up camera
Old Feb 5, 2022 | 06:43 AM
Striderwv's Avatar
Striderwv
If u have an obdii port, Forscan is the way I would go with a dedicated tablet or phone. Then you would have it for troubleshootin. Will monitor everything except FP, You will need a seperate gauge for that. I use the wifi reader.
Amazon.com: BAFX Products 8523900508 for for iOS Devices OBD Reader for Check Engine Lights & Other Diagnostics: Gateway Amazon.com: BAFX Products 8523900508 for for iOS Devices OBD Reader for Check Engine Lights & Other Diagnostics: Gateway
Download FORScan
Old Feb 5, 2022 | 08:28 AM
Baylinerchuck's Avatar
Baylinerchuck
I’ve been happy with the Edge CTS2 tuner, but they have a straight monitor that’s a bit cheaper. I purchased their gauge pod which makes the install really clean, almost factory. Additional add ons like EGT, and fuel pressure get a little pricey. I do like having everything in one touch screen.
Old Feb 5, 2022 | 08:38 AM
00t444e's Avatar
00t444e
Get the Edge CTS with the expandable competition kit that way you can monitor EGT and you true boost instead of reading off of the MAP sensor.
waystro
Aug 6, 2014 12:51 AM
Chrisaudax
Mar 14, 2011 08:10 PM
7.3 Rocket
25
Feb 17, 2009 08:42 PM
kemerick
May 11, 2005 10:31 AM
