ISSPRO faceplates replaceable?
I ordered the post turbo gauge and ended up mounting it pre turbo in the exhaust manifold.
Or, you could rethink your gauge pod and install the Pre & Post Turbo EGT Gauges. (you'll need the other gauge and thermocouple though.) If you've got an automatic, I can see it now. Pre/Post EGT and Trans temp in the tripple pod. And a single pod on the column with the Boost gauge.
With the ZF6spd, I've got the Boost and both EGT gauges in the tripple pod.
If you didn't actually install the gauge, I'll bet that MotorHaven will exchange it for you.
