Cars with 24 volt electrical system?
The only 24V vehicle I've seen was a '52 GMC M135 6x6 military truck. And it was a generator, not an alternator.
I find several with a simple search, for tractors and other equipment.
https://www.ebay.com/p/15042398547?iid=185239585794
$120+ to over $400.
You want a $10 junkyard one, you might be looking for a while.
$120+ to over $400.
The following 2 users liked this post by JWA:
All the airport vehicles I've seen have been 12V; but I've only worked around small to medium aircraft, not the big jets. I wonder if ambulances ever have 24V...
My intention is to have an emergency backup charging method for an off-grid solar 24V system. This means I need an alt with a respectable amp output (to minimize engine running time), and since it's only for rare use, I can't really justify spending $400+ in addition to mounting and wiring. A bunch of candles would be more cost-effective
Unless you are going to try to turn the alternator using wind.....
Those links and other suggest different types of equipment like Komatsu, Hitachi, Deere, Cat, Case and other ag equipment.
Hours of entertainment possible here:
Short version: If you take off the voltage regulator and spin it hard enough, you can get 25 volts out of a 12V alternator. Some assembly required. Not sure you could spin one 4000 rpm with wind power.....
A regular generator would be a better backup. More versatile, probably safer.
https://www.youtube.com/watch?v=oRaQXd0u37c
I quoted you because of your comment "....Back up charging for a solar system makes no sense as solar provides charging."
Which I agree with, and added that if he needs a backup, a regular generator would be a better idea. Because "Back up charging for a solar system makes no sense as solar provides charging.'
So it's a quote, not a criticism.
I knew someone would say this! Not that there's anything wrong with that idea, but I personally I don't care for it because (1) portable generators are not really known for being super reliable; I have more faith in the old diesel tractor, (2) both the tractor and my truck are diesel, so it would be an annoyance to store gasoline just for a generator that I hardly ever use, (3) a regular AC generator would require a separate 120VAC to 24VDC high-amp charger, which is a complex and expensive piece of electronics, and (4) the alternator idea would just be more fun to build!
Anyways, if this idea turns out to be too much trouble/expense I just won't bother with it; but it would be fun to do.
Received 3,195 Likes
on
on
mh48
08-19-2006 06:10 PM
bryan_johnson
General Automotive Discussion
16
02-16-2006 12:00 PM
keja1914
24
03-03-2005 06:54 AM
