Charging system
Old Apr 3, 2006 | 12:10 AM
ol'blue52's Avatar
ol'blue52
Charging system
I'm going to rewire my 52 F-1. I'm undecided whether to use my 12 volt generator or to upgrade to and alternator. The truck will be converted to 12 volts. I'm not sure if the gen I have works as it came with my second engine and I've never run it. The one wire alt. would be much more simple to wire, but is there really that much of an advantage. What is the real difference between the two? Thanks for the info.
Old Apr 3, 2006 | 12:23 AM
TBucketJack's Avatar
TBucketJack
The alternator is the only way to go. It will charge at idle and will handle the additional loads put on a battery by A/C, stereo systems, and other accessories.
Old Apr 3, 2006 | 06:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Any alternator will perform just fine. The 1-wires rated 100+ amps are overkill for an old truck unless you're running A/C, EFI, power windows, and a bunch of extra lights. 45-50 amps is plenty. The big advantage of a 1-wire on a 8BA flathead is just that there are a bunch of turnkey kits that bolt them up (I went with a Certified Electric set-up). I agree it is dynamite compared to a generator/regulator setup.
Before I sprung for the kit, I looked hard at making a Ford alternator I had laying around fit the stock flattie gen mount. It looked like it could be done pretty easily, also looked like an alternator from a late 80's Chev/GM truck was the same diameter as the original gennie and could be adapted easily, but then I'd have to figure out the wiring. I admit it, I took the easy way out -- wrote the check and didn't look back!
Old Apr 3, 2006 | 07:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Use an alternator. The generator is a dinosaur. There must be a reason they don't put them on new cars...
Vern
joezzz
Nov 29, 2012 10:09 PM
52' fordnut
53
Sep 15, 2012 11:19 PM
19fifty4
May 25, 2012 11:18 PM
oldblue92
31
Jul 19, 2009 10:36 AM
RSempel
Indiana Chapter
Oct 21, 2006 08:43 AM
