Sponsored by: Auxito
Sluggish power, fluctuation under load
Old Feb 1, 2022 | 09:11 PM
PlzGod!LetThisUsernameBOk's Avatar
2nd Gear
Hey y’all, I have a 2000 F150 with a 5.4L. It has recently started exhibiting sluggish takeoff and seemingly reduced HP under load (constant lug uphill). The reduced HP feeling under a load is accompanied with a surge of sorts similar to a A/C compressor draw but more random with no rhythm. Keep in mind, AC is off. Something I noticed tonight, which initiated this post, is that when the truck is cold, it runs like a top! As soon it warms up just slightly (just a few miles of driving) it turns into a turd. What could be causing the difference in performance from cold open loop to warm closed loop?
Old Feb 1, 2022 | 09:20 PM
Jon Freeman's Avatar
Jon Freeman
Could be a misfire problem. Did you check for codes ?
Old Jul 7, 2022 | 07:53 AM
2nd Gear
I did. The check engine light is off however I still checked in case the bulb was burned out. No codes. Engine runs smoothly, just lame.
Old Jul 7, 2022 | 10:55 AM
Jon Freeman
read through this article for tips:
https://completecar.ca/maintenance/r...while-driving/
Old Jul 7, 2022 | 04:13 PM
WWR's Avatar
WWR
You want to get into OnBoard Monitoring or Mode 6 and look for misfire counts. Also check Pending codes
That said I'm not sure misfires would be your only issue. Would be nice to see some live data as it sounds like an open/closed loop issue maybe. I'd be curious about ECT, STFT, HEGO, TPS and maybe fuel pressure just for giggles
jccapri
23
Jul 28, 2013 08:47 PM
bla1879
1997 - 2003 F150
Aug 10, 2007 09:01 PM
Fershigadig
Aug 14, 2006 09:34 PM
zman764
1997 - 2003 F150
Apr 16, 2006 10:50 PM
mach1466
Aug 10, 2005 03:51 PM
