Brake Controller Wiring Questions
Old Jan 30, 2022 | 07:33 AM
mikenc's Avatar
mikenc
Hi all - I'm installing a brake controller and have some questions about the wiring:
I need 2 hot wires from the battery - both are fused and one goes to the controller in the cab and one goes back to the plug on the hitch. Can I add these to the hot side of the starter solenoid, rather than to the battery terminal itself?
I need a ground to the brake controller in the cab. Can I ground it somewhere in the cab or should I fish a wire from the battery ground through the firewall to the cab?
Old Jan 30, 2022 | 09:34 AM
dustyroad's Avatar
dustyroad
I went direct to battery on the 2 hot wires but those are going to be moved to a bus bar soon.
I also routed the ground to a ground bus bar on my firewall, you could probably do what you described without issues.. I just figured direct was better.
Old Jan 30, 2022 | 09:56 AM
Conanski's Avatar
Conanski
Ground in the cab is fine for the controller, the two hot wires must be fused and the exact location you pick that up isn't critical as long it has sufficient current capacity, so yes the hot side of the starter relay would work.
Old Jan 30, 2022 | 09:57 AM
Franklin2's Avatar
Franklin2
I followed the instructions with the controller. All the controllers I have installed say to run the white ground wire directly to the battery negative terminal. For the power wires, I usually run a circuit breaker instead of a fuse, so when out on the road if the problem is resolved it comes back on and starts working.
Old Jan 30, 2022 | 10:04 AM
dustyroad's Avatar
dustyroad
I assumed he was installing a kit, which it should come with circuit breakers. Mine did.
My ground bus bar is ran directly to the battery with no issues so I think it's safe to run the ground anywhere just make sure it's a good ground.
I just didn't want multiple wires snaking back to the battery for a ground.
So different answers that achieve the same result. so that says to me it doesn't really matter how you connect it, as long as you have good solid connections.
Old Jan 30, 2022 | 11:51 AM
mikenc's Avatar
mikenc
Thanks y'all. It's a kit and has 2 fuses to put inline for the 2 power connections and they are self-resetting or whatever you call it.
I just figured I can put some ring connectors on the 2 hot wires and come from the starter solenoid instead of messing with the battery terminal. It's once-removed from the battery terminal and it meets the intent of the diagram that came with the kit, it's just not literally the same.
Going to give it a shot and see - thanks again.
Old Jan 30, 2022 | 02:08 PM
Max Capacity's Avatar
Max Capacity
Go to the battery terminal.
Old Jan 31, 2022 | 03:34 AM
FuzzFace2's Avatar
FuzzFace2
I went to the hot side of the solenoid and used breakers.
Now it sounded like only 1 wire from battery hot was for the brake controller and the other a hot to charge a battery on the trailer.
IIRC the controller has 4 wires
Hot all the to battery
Hot with key on
Brake light tie in
Out to trailer brakes.
I ran 10 Guage wire for powerto charge trailer battery & out put of controller to brakes on trailer.
Dave. ----
Linusthedog
All Things Towing
Jul 1, 2025 11:51 PM
JBrent
All Things Towing
Oct 2, 2004 01:57 AM
phi22b@ck
1997 - 2003 F150
Feb 25, 2003 12:21 AM
npaul
All Things Towing
Dec 18, 2001 04:34 PM
sharlo
1997 - 2003 F150
Jan 2, 2001 03:46 PM
