2003 6.0 No Start
I double-checked ficm connectors to make sure none of the wires backed out, all the pins on the ficm are straight, all 3 plugs click in.
I haven’t done the hpo leak test, I didn’t think it was necessary with my ICP and IPR readings. Should it be done?
When you said you did the bubble test and it passed, which bubble test did you do? There are two (one while filling the fuel bowl, and one when cranking)
You tried a known good FICM and you posted that it seemed to help (based on post #13). If it helped any, then you have that to address.
No need to do an air test when you are getting well over 500 psi when cranking.
How old are your injectors and where were they purchased if they are not the originals?
I have suggested a few times that it is your injectors. If they will not buzz when commanded, then it is the FICM, the wiring, or the injector.
When you said you did the bubble test and it passed, which bubble test did you do? There are two (one while filling the fuel bowl, and one when cranking) I did the one while cranking with the jumper wire. Not familiar with the first one.
You tried a known good FICM and you posted that it seemed to help (based on post #13). If it helped any, then you have that to address. It had different programming, earlier Ford programming than mine, and cycled the injectors differently(at KOEO and after key off). I can't with confidence say that it made any positive improvements with the other ficm. I did hear more injectors buzz, but I also had the block heater plugged in for several hours prior to the swap and unfortunately do not recall if I checked my ficm with the warm block before the swap. After swapping back I had multiple injectors buzzing with my ficm. But the injector buzzing was and has been inconsistent with both ficm's. Also, the cranking sounded the same between the two ficm's, like only a single cylinder trying to fire on the right bank.
No need to do an air test when you are getting well over 500 psi when cranking. That's what I was thinking, but someone told me I still need to do it.
How old are your injectors and where were they purchased if they are not the originals? They may be the originals, I just found the PO's number, he's the original owner, I'm going to give him a call today.
I have suggested a few times that it is your injectors. If they will not buzz when commanded, then it is the FICM, the wiring, or the injector. I'm going back and forth with the ficm possibly being a problem, it did work in my dad's truck, cycled all the injectors and ran perfect. But I don't know enough about ficm's to know if that's a for sure tell that it's good. As for wiring, what else should I be looking at? And if it's injectors, what could cause the injectors to **** the bed that quickly?
Have you done all the oil maintenance on time?
Are you using 15W40 oil below 20 *F?
Are you using a tall oil filter cap with a short OEM oil filter?
The other bubble test is to see if air is getting into the fuel from anywhere between the tank and the fuel pump.
Remove the secondary fuel filter.
Remove any standing fuel in the filter bowl.
Have someone turn the key n while you watch the filter bowl fill up. Be prepared to have your friend ready to shut off the key quickly!
If you see any bubbles while the bowl is filling, then that is an issue.
Have you done all the oil maintenance on time? Always 5000-7500, never over, never low on dipstick at oil change
Are you using 15W40 oil below 20 *F? 5W40 Rotella T6 since I bought it at 137k miles
Are you using a tall oil filter cap with a short OEM oil filter? Only Motorcraft FL2016 filters, Sinister Diesel cap
If you see any bubbles while the bowl is filling, then that is an issue. I’ll add this to the list for testing today.
One probe on pin 1 and the other probe on the battery (-) terminal (key on)
What do you get? (if you don't know which pin is the 12V power, then check voltage on both pins relative to ground - one shoul be over 10V and the other at 0).
Ignore AK3 and AK7 unless you have a means to command the vgt solenoid
I have a new OEM ficm/injector harness showing up this week. Also a new ficm relay possibly tomorrow. I’m going to call circuit board medics about my ficm in the AM and send that off to them for testing (should probably try the new relay first). I’m undecided if I’ll pull the injectors now or wait for the ficm to be checked out, test it again, then pull them if still no start. Not sure what else to check.
If I strike out with the relay and ficm and remove the injectors my plan was to send them somewhere like Diesel Injectors So Cal for rebuilding, any experience out there with injector shops rebuilding 6.0 injectors? Injector shops should be able to bench test the injectors to confirm health correct?
I’ll post up tomorrow if the relay shows up and makes any difference.
