2003 6.0 No Start
Old Jan 30, 2022 | 01:28 PM
pnw_at's Avatar
pnw_at
I returned pcm/tcm back to stock programming after re-installing my original ficm (wasn’t sure if leaving the other ficm on during reprogram would change it’s programming) and the engine does sound like it’s trying to fire, same as it did with the “known good ficm” I tried, and the injectors have the same audible tone now as with the other ficm (side note the truck has been plugged in since yesterday and EOT is probably ~90F) but I didn’t get any of the dtc’s I saw with that other ficm even after a few crank cycles. I did, as a hail mary, unplug the icp and try cranking again, and it cranked with no sign of trying to fire. I did wiggle wire harnesses and had P0670 pop up (Gpcm related) but it didn’t come back after a reset and another KOEO.
I haven’t had any injector-related dtc’s at any point that came back, but I guess I also haven’t had the truck running to run a balance test, but I don’t know if I should be thinking about going right to injectors right now?? And if that is the recommended course of action where should I be calling for injector rebuilding service?
At this point I’ll start removing the wire harnesses for close inspection and testing.
Old Jan 30, 2022 | 01:29 PM
bismic's Avatar
bismic
try unplugging injector #5 and trying to start
Old Jan 30, 2022 | 01:34 PM
pnw_at's Avatar
pnw_at
Should I plug the ICP back in when I try that?
Old Jan 30, 2022 | 01:42 PM
bismic's Avatar
bismic
Probably doesn't matter.
Old Jan 30, 2022 | 02:17 PM
pnw_at's Avatar
pnw_at
Unplugged #5 and got P0273. No sign of trying to fire, ICP is still unplugged.
Old Jan 30, 2022 | 02:32 PM
bismic's Avatar
bismic
This is when I wish we had an inexpensive way to do an uncompensated contribution test. Worth considering taking it in.
That said, where I was going with the disconnecting of #5 is that one injector solenoid shorting out might affect the performance of the others.
Unfortunately you didn't see any other injector identified as an issue (codes).
Have you addressed the P0046 - VGT connector/wiring short? Maybe that is pulling down the VPOWER
Old Jan 30, 2022 | 05:13 PM
pnw_at's Avatar
pnw_at
Yeah, I’m thinking the same, it’s a pita when there’s no solid dtc(s) to run off of. The VGT dtc didn’t come back after re-installing my ficm and reverting to stock programming. I did look at the wires for any chaffing and pulled the plug and re-installed, but maybe I should dive further into that and check the pid’s during KOEO and cranking.
*I should add again that I probably had the vacuum pump connector disconnected when that VGT code popped up, and my cold side cac is off, not sure if either could cause it but felt it was relevant.
Old Jan 30, 2022 | 05:23 PM
bismic's Avatar
bismic
The vacuum pump would have absolutely nothing to do with it.
Old Jan 30, 2022 | 05:25 PM
pnw_at's Avatar
pnw_at
Ok good to know, just making sure I’m providing all the info that could be relevant.
Old Jan 30, 2022 | 06:41 PM
pnw_at's Avatar
pnw_at
Checked ohms between vgt solenoid connector and pcm connector at pins 10&11, 0.4 ohms on both. Checked vgt solenoid pins, 3.7 ohms.
Old Jan 30, 2022 | 07:57 PM
DSMMH's Avatar
DSMMH
This is a WAG. But when you changed your secondary fuel filter the last time, did you install it in the top first then put it on the spring loaded shutoff valve? If the filter twists or crushes slightly, it will not completely open the shutoff valve and over time the valve will complete shut. Been there, done that. I know you have fuel pressure. Not sure if the pressure is measured on the pump or injector side of the fuel bowl. Might be worth a check.
Ed
Old Jan 30, 2022 | 08:10 PM
pnw_at's Avatar
pnw_at
Ed
I always place it in the bowl and then reinstall the cap, and I did not deviate after I did the bubble test, but it's worth checking because nothing can be overlooked at this point. Thanks. If you think of anything else send it my way.
And I'm checking pressure at the port on the side of the bowl by the pressure regulator cover. I don't have a gauge tapped into the cap.
Old Jan 30, 2022 | 08:20 PM
  #28
bismic's Avatar
bismic
AK2 DIAGNOSTIC TROUBLE CODE (DTC) P0046
  • Key off.
  • Disconnect the VGT actuator electrical connector.
  • Key on.
  • Measure the voltage between the VGT electrical connector pin 1 and ground.
Is the voltage greater than 11.0 volts?
AK3 is taking active control of VGT and testing (if you have that ability)
AK7 is referenced and it is for cleaning the VGT
AK4 CHECK VGT CONTROL CIRCUIT FOR A SHORT TO VOLTAGE
  • Key off.
  • Remove the test light.
  • Disconnect the PCM engine harness electrical connector.
  • Key on.
  • Measure the voltage between the VGT actuator harness connector pin 2 and ground.
Is the voltage less than 0.2 volts?
AK5 CHECK VGT CONTROL CIRCUIT FOR A SHORT TO GROUND
  • Key off.
  • Measure the resistance between VGT actuator connector pin 2 and ground.
Is the resistance greater than 10,000 ohms?
AK6 CHECK VGT CONTROL CIRCUIT FOR AN OPEN
  • Measure the resistance between the VGT actuator connector pin 2 and PCM connector pin 10.
Is the resistance less than 5 ohms?
Old Jan 30, 2022 | 08:21 PM
  #29
bismic's Avatar
bismic
You might try cranking with other injectors disconnected (one-at-a-time). I hesitate to suggest that guessing, but it is at least free guessing.
Old Jan 30, 2022 | 09:17 PM
  #30
pnw_at's Avatar
pnw_at
  • Key off.
  • Key on.
  • Key off.
  • Key on.
  • Key off.
I'll do all these tests tomorrow. Thanks for sending this info.
