Vacuum hose fitting?
Old Jan 27, 2022 | 08:37 AM
Caleb83F150's Avatar
Caleb83F150
I have the hose fitting on the back of my intake manifold and I don’t know what it is or where to find a diagram for it. It’s on my 1983 f150 with a 302. What is it?
Fitting behind carb
Old Jan 27, 2022 | 10:41 AM
Franklin2's Avatar
Franklin2
I am not sure I am seeing it? Is it that decent size hose right behind the square plug and it's open?
Old Jan 27, 2022 | 12:01 PM
Caleb83F150
It is connected it just loops back around and goes into a fitting right beneath it, it’s just kind of hard to see.
Old Jan 27, 2022 | 01:57 PM
kr98664's Avatar
kr98664
Are you talking about the big Christmas tree fitting at the aft center of the intake manifold? Here’s a picture on my 351W:
The fat line on the end goes to the power brake booster. The smaller lines go to various points on the engine, the HVAC door actuators, and the speed control servo.
Depending on the equipment installed, not all ports on this fitting are used. The unused fittings are capped. If you have a line looped between two of these ports, I bet a cap or two fell off and somebody “fixed” it by connecting a hose. Might have been easier than trying to find replacement caps.
You can see this fitting on the emissions vacuum diagram. There should be one on a valve cover and another next to the hood latch. Here’s mine, which only shows one line from this fitting, to the air cleaner heated intake system.
The diagram doesn’t show the brake booster, HVAC, or speed control because those aren’t emissions-related, even though they use the same vacuum source.
Old Jan 27, 2022 | 02:04 PM
Caleb83F150
yes that was what I was talking about, this was a barn find and it’s pretty much a Frankenstein of a truck 😂. Thanks for the help!
Tucker Dunn
May 17, 2021 01:57 PM
old28
Jul 18, 2020 06:57 PM
RobertELee
Feb 16, 2019 04:53 AM
DSMCasey
1997 - 2003 F150
Oct 5, 2016 08:24 PM
magman0101
May 27, 2015 04:48 PM
