1978 - 1996 Big Bronco
warning buzzer
Old Nov 5, 2003 | 06:32 PM
mtm1972's Avatar
mtm1972
warning buzzer
OK, so I'm driving along and the warning buzzer comes on for no reason. Actually it's more like a bell. Anyway, I can't figure out why it stays on. If the doors are closed (tried jiggling the jamb switch already) and the engine is running, why else would the warning come on? I usually only hear it if I either leave the lights on and take the key, or the key is on and the door is open. Could it be a short? Since it is pitch black and pouring rain outside, can somebody tell me exactly where to find the actual buzzer? I need to disconnect it until I have a chance to poke around. Thanks.
Old Nov 8, 2003 | 06:42 PM
steve83's Avatar
steve83
It could be the door switches - grab the black mushroom-headed pins and pull gently but firmly STRAIGHT outward. You should see a brass sleeve slide out ~1/4". Then close the doors. That will reset the switches. You can probably find a photo of them in my signature link.
Old Nov 9, 2003 | 07:52 AM
Black Ford XLT's Avatar
Black Ford XLT
warning
I had the same thing happen before on the way to work CULPRIT bad door mushroom switch. hope this helps TR
Blujay96
May 4, 2010 07:47 PM
skeneguy
Dec 2, 2005 05:40 AM
douglas1988
Electrical Systems/Wiring
Jan 13, 2005 06:31 AM
doug023
Nov 4, 2003 12:48 PM
RangerRuss
1997 - 2003 F150
Oct 31, 2003 06:28 AM
